My heater is intermittently purging glycol out the overflow drain. I have "burped" the unit even though it is supposed to do it on its ow and ensured the reservoir is filled to just at the minimum. Does it even when the unit is level. I have to keep adding fluid. Any ideas?
0 ·
Following up on Sharon's comments, what are you actually referring to when you say the "overflow drain?" Do you mean the black tube from the air bleeder assembly or the overflow hose from the expansion tank? Either can spill glycol, but the solution will differ depending on the source of the leak.
If you look at the document I posted here, there is a section with photos that describes how to adjust the pump speed. It may depend on your specific model and configuration.
