Where can I find the mixing Valve??
In our New 2021 Tab 400 We are only getting hot water for 10 seconds at a time.... I see the answer for that is to adjust the mixing valve for the alde system. For the life of me I CANNOT FIND WHERE THE MIXING VALVE IS LOCATED IN MY TRAILER!!!!" anyone???
    Under the bed over on the driver side near your plumbing and Alde.
    edited June 2021
    This is what you are looking for, it has a red knob on top (not shown), remove the top and use it to adjust the valve under it:
    On the 2021 TaB400, you have to unscrew the plywood bottom under the drivers (left) side of the bunk, this is also where the Alde hot water tank drain/overflow valve is (yellow handle).
