At home getting ready for a trip, pluged into 15 amp outlet. Turned on refer. Then a while later I unpluged from the 15 amps Without turning off the refer. I then pluged back into the garage 15 amps and the refer won't work. Is there a reset button? Advice?
0 ·
Also, check to see if the GFCI on the trailer's exterior outlet (and inside as well) may have tripped. That will cut the power to your trailer outlets. Check the GFCI for the house outlet as well (assuming you plugged in to a GFCI protected circuit.) It is possible that one of the GFCIs (house or trailer) tripped when you unplugged the 15 amp plug.
Looks like 6 hours to get to this point.
Mine has three additional glass fuses located on top of the unit, accessed by removing the stove top. IIRC, one of those fuses is for the DC circuitry, another is for the DC heating element, and the third is for the AC heating element. If that third one is blown, the fridge won't cool on AC.
If yours is still not cooling down, it might be worth seeing if you have those same fuses. Your fridge owner's manual should offer info as to their exact location.
