All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Norcold Fridge shutting off on Propane
Hi. I have a 2018 320S Boondock with the 3-way Norcold fridge. Last weekend, while the fridge was running on propane, I noticed the fridge wasn't running and warm. When I started it again I noticed the gauge showed barely on the line between white and green which was a little lower than normal. Then I noticed it would bounce around if I flicked it with my finger. I got it going again a couple times, but also noticed that the flame would go out right when I closed the fridge top cover (covering the controls). Weird! Loose connection? One or two issues?
I noticed a soot buildup around the thermocouple and chimney as well so I cleaned that on site. Really hard to get the soot off the thermocouple though, and really hard to get the thermocouple out. Anyway, I got it cleaned and started again a couple times, but the flame just kept going out over time, or when I closed the fridge top cover. The thermocouple seems to be in partial flame where it should be. Faulty?
Back home today I removed the cooktop and looked inside remembering someone posting awhile ago about loose connections. I didn't notice any, but wiggling them around seems to have made the gauge read more onto the green side now. Not a good sign. The propane starts first click of the ignitor, and the gauge now reads well into the green like it used to last year, but I don't know if it's going to go out after awhile next time camping. Any experience with these issues? I did a search but there's so many to go through.
Dean
Adventure Canadian Style
2018 Tab320s Boondock Edition, 2018 Toyota Forerunner TRD
