Long story short, I was under the camper today to adjust the drum brakes as one side seemed to be hotter than the other side (and had some burning brake smell) after our past weekend trip. I figured the brakes could use an adjustment. Easy task.
While under the camper today I noticed the brake wire had so much slack in it that it was rubbing against the tire and is nearly split!
Some of you may have seen my post about the quality control issues we've been having with out trailer:
https://tab-rv.vanillacommunity.com/discussion/13753/400-amazing-trailer-terrible-qc#latestThe issues before seem minor now compared to this one. I'm sure I can splice the wire back together somehow but how do you leave a wire hanging with so much slack? Common sense would tell you it's going to rub against the tire.
I'm posting this as a caution for anybody who cares to go and check the slack on your electric brake cables and secure them so they aren't dangling. I've got an email into to NuCamp to see what they have to say.
Just when we were starting to turn a corner and beginning to enjoy this trailer, I find this.
Nucamp did a good job on the heat shrink tubing but I was surprised they didn't use waterproof butt connectors. The black tubing isn't necessarily waterproof so using waterproof connectors is good practice.
2020 Tacoma TRD Off-Road
A new issue I'm now working out is why the passenger brake drum gets hotter than the drivers. Stay tuned.
Interestingly my Tacoma has the same issue but just not as extreme. Maybe a 10% temp difference after some spirited braking.
Limited-time deal: Etekcity Infrared Thermometer 749 (Not for Human) Temperature Gun Non-Contact Digital Laser IR Thermometer-58℉~ 716℉ (-50℃ ~ 380℃), Standard Size, Black-Yellow https://www.amazon.com/dp/B07QZ1849H/ref=cm_sw_r_cp_api_glt_fabc_dl_A2H6C6N9MPSKXNP0QCKT?_encoding=UTF8&psc=1
This is a MANUFACTURER DEFECT and lifesafety issue.
Nucamp told us we are not warranteed, having bought a thirty day old secondhand trailer from original buyer.
Lift insert in spare tyre has diameter 6 mils greater than hub opening and forces spare cockeyed until laboriously removed, ground with angle grindrr, and reinstalled requiring $73 cable swedging tool. Useless rear aluminum rack misfabricated in factory but installed anyway with foot bolted to trailer at 42 degree angle rather than aligned. Door trim with failung doublestick tape. Unresolved NO PROPANE AT ALTITUDE, WELL KNOWN. Unresolved Alde thermostat reading way off tens if degrees
Trailer jack does not clear tailgates of Tacoma, Ranger, other half ton trucks... Does no one tow with these?
(someone mentioned one brake drum being hotter than the other; that can happen if the first drum is getting proper power, but the other is getting power through a wire that’s missing a few strands.)
2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter|EMS|SoftStart)
2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
https://revkit.com/donmontalvo/ | https://donmontalvo.com
it is a much more polite and productive approach than venting at the company…though every once in a while I am guilty of violating Wheaton’s Law…
2024 NuCamp T@B 400 BD, Charcoal / White
2024 Kia EV9
