Axle question - do we need to put 320 CS on blocks?
mmcneil72
mmcneil72 Member Posts: 48
Friend insists that our 2017 T@B 320 CS should be up on blocks - i.e. on jack stands so trailer wheels and axle aren't bearing the weight of the T@B.  Is this true?  Friend is a long-time RVer and experienced mechanic, so seems like a good idea.  Something about avoiding stress on the axle's torque arm?
At some point we may consider swapping in a Boondock style axle as we love camping but don't like the trailer park style campground very much, so 'rough' camping (aka overland etc.) preferred.
(Full disclosure - complete noobs to RVing but T@B performed like a champ during initial Rocky Mountain family camp out, including torrential rain the first night.)
    pthomas745 Administrator, Moderator Posts: 4,684
    Does the mechanic friend put his cars up on blocks?
  • mmcneil72
    Something something about the T@B's axle wearing out prematurely from just sitting on its tires.  Greek to me - don't really know who made the axle.  Has the nice cast rims, new or very recent tires.  Have space to park it and/or jack it up.
  • AnOldUR
    AnOldUR Member Posts: 1,759
    The T@B struts are for stabilizing and should not be used to support the weight of the trailer. Never try to lift the trailer with them. It will cause damage to the stabilizer. Once level, drop them down and add a small amount of additional pressure. Just enough to keep it from rocking when you’re inside.
    ScottG Administrator Posts: 5,693
    The axle is what is commonly known as a torsion axle--suspension is provided by internal rubber blocks (or something similar) that resist and dampen the motion of the swingarm to which the wheel is mounted.
    I suppose theoretically that relieving the pressure on the blocks and swingarm may prolong their life, but I've never heard it recommended, I don't know of anyone that does it, and I've never heard of a T@B torsion axle failing in this regard. I suspect bouncing the trailer down the road puts far more wear on the axle components than the static forces it experiences just sitting parked.
    I could be wrong. I also don't use a surge protector, a water filter, a fancy battery monitor, or a spare tire cover, so risk-averse types may be better served avoiding my advice!  ;-)
  • webers3
    webers3 Member Posts: 449
    @ScottG we are camping on the edge
  • BrianZ
    BrianZ Member Posts: 1,770
    Here ya go..  explanation & illustration of how torflex axles work..
    https://youtu.be/MzDW1OUbmHc
  • elbereth
    elbereth Member Posts: 105
    @ScottG we have fun with our toys, so we do have a fancy battery monitor, a surge protector, and use a water filter, but have never gotten the spare tire out from under the T@B so… :)
    anyways, @mmcneil72, we have a 2018 CS-S that we keep happily garaged on its own 2 wheels.  I lube the bearings through the Zerk fitting each spring but otherwise have given no thought to the axle.  I think you’re safe!
    2018 T@B CS-S Towed by 2015 Subaru Outback 2.5i in the wilds of Minnesota
  • Dalehelman
    Can’t hurt. It kinda depends on how long it sits without moving IMHO.
    1. Hash  T@B Fun
    @elebereth, you have all those fancy accessories but you don't disassemble, inspect, and repack your wheel bearings every twelve months! I think you have an inner daredevil trying to break free!
    Do I dare ask when you last changed the glycol in your Alde! Quelle horreur!  ;-)
  • RogerL
    RogerL Member Posts: 24
    from the Dexter axle manual:
    If your trailer is to be stored for an extended period of time or over the winter, it is important that the trailer be prepared properly.
    2. Jack up the trailer and place jack stands under the trailer frame so that the weight will be off the tires. Follow trailer manufacturer’s guidelines to lift and support the unit. Never jack up or place jack stands on the axle tube or on the equalizers.
    2018 T@B 320CS-S, 2018 GMC Canyon SLT
    Urbana, MD
  • Dalehelman
    ScottG said:
    Well there's your answer... Don't store your trailer for an extended period!  ;-)
    Perfect 👍
    1. Hash  T@B Fun
  • elbereth
    @ScottG for the win!
