After many email inquiries, I finally received a note and attachment from Horrex (manufacturer of the blinds/shades - at least for the 2016 models. Not sure if others have this kind). Although it does not show what to do if the white strings come out (the unit comes pre-assembled, except for the last step), it may help if you have to take the unit off the wall. In one of the photos it says to be sure the white and black strings are not crossed or intertwined. This was what definitely happened to mine (whoever installed it at the factory had them twisted). Just wanted to pass this on to the group.
2 ·
Also front shade sags at the top. Been trying to find out if it can be reinforced or braced somehow.
Thanks
Looks pretty much like I recall my old one looking.
PXL - The white strings lay in this channel and then pushed down through the black piece (see pic), then up the sides. The black piece is narrower at the very end so it's supposed to hold the string in, but in reality it can be pulled out fairly easily.
I think it gets off track the string messed up when you pull it up or down with one hand. It seems that adjusting the height with one hand in each side might help keep it more level.
Thoughts?
Once Again This Forum Has THE Answer
mickietucs said: After many email inquiries, I finally received a note and attachment from Horrex (manufacturer of the blinds/shades - at least for the 2016 models. Just wanted to pass this on to the group.Thanks for the posting & file.
My passenger side screen was not working ideally from the factory, with one black string swinging free. Yesterday returning from my most recent (4th outing) that included a long section of very poor condition interstate arrived home to find the screen diagonal in the window and several inches of screen out of the side track/guide.
So it was, search the forum, find ideas, even better find a manufacturer instruction sheet !
All gave me the confidence to dig in . . . . and such a simple fix . . . so I checked all the windows for correct assembly.
Front window on a fresh from the factory 2019 320s is having shade problems; screen pulls down, shade only goes up about 2”. Looking at the strings versus those of the side windows, they aren’t merely out of place, but twisted together more than once on both sides of the frame. Popped out lower corner trim and there are no screws securing the frame to the walls, though screws are present in the top corners. Does anyone know if the front window inside frames are attached differently in the most recent models? Or even better, how to untangle and realign the strings without removing the frame from the wall?
Trying to avoid a dealer visit because I probably can’t manage one before my next scheduled trip.
mine string came out of rail day1 if purchase of my 2021 Tab 350 S Boondock
I tried everything nothing worked…
Finally my sister came over.
I went inside the camper.
I asked my sister to pull that lose string as close as possible to the channel in the side of the window where it came out from.
I was able to gently put the string back in with a flat head screwdriver
Problem solved.
having my sisters every help to bring that string close (needs tension) it allows me to tuck that string back in the area where it came out from
https://tab-rv.vanillacommunity.com/discussion/6399/windows-awnings-shades-and-screens#latest
2021 T@B 320 BD
TV: 2021 Toyota 4Runner
2021 T@B BD - 2021 4Runner
I received this link from the manufacturer distributor (http://transatlanticprod.com) with some videos showing how to restring the shades along with how to remove and install them.
https://1drv.ms/f/s!AhhCEOni5lJpkR0ew5-aX5jtLBXU
I had some problems when my unit was under warranty and they sent me a bag full of replacement parts (way more than I needed) along with the link above on how to fix it. It was welcome news as I was tired of hearing "bring it back to the dealer to get it fixed".
