On the receptacle where the Zamp solar panels plugs into, which is positive......the male or female connector?
I purchased a new receptacle and it has a red and black wire where the old one had a red and white wire. With the old receptacle, the red was positive and the white was negative.
Thanks
But re-reading to original post, I see he's asking about the receptacle, not the plug.
Sorry to have possibly caused some confusion.
Toronto, Canada
My advice to all: your toolbox should have a simple multimeter, get it, learn it, use it.
Brent
Toronto, Canada
https://tab-rv.vanillacommunity.com/discussion/6230/zamp-solar-connections-explained
Renogy DC-DC Charger Installation (vanillacommunity.com)
My future includes replacing the SAE connector I installed in my tub with one of these. My initial concept of switching to Anderson connectors was to make my Renogy briefcases capable of charging my Yeti Goal Zero (that came with the Anderson connector) when they weren't charging the T@B.
After reading through this discussion it seems that there may be an inherent safety advantage to the Anderson connectors too, as no conductors are ever exposed.
2019 320 Boondock Edge - Sold Jan 2022
