I ordered a Renogy 100W Eclipse Monocrystalline Solar Suitcase, but Amazon sent me a the lower priced non "Eclipse" version. I set up a return and ordered a replacement, but am curious if any of you knows what makes these so different. Although they're both 12V/100W, the weight, dimensions and some of the electrical specs are not the same. I would guess that the Eclipse is the newer, better version based on price alone, but I can't find anything to back that up. Has anyone researched this and gained some knowledge that they would share? Thanks.
I recently disconnected the PWM controller to use the panel with a separate MPPT controller, as your planning to do. It was a simple task, four screws to disconnect the wires. I left the original controller attached, since it isn't in the way of anything.
2019 320 Boondock Edge - Sold Jan 2022
Good luck. Let us know how you tie in the portable panels to the installed controller. You may be one of the first to do so.
My briefcase line enters the back of the tub using an SAE, just like yours (no need to post a pic of that). Hope this gives you some ideas for your install...
