I'm preparing to install a Victron SmartSolar 100/20, and ran across something I hadn't planned on.
The SmartSolar 100/200 has a case or chassis ground screw - which I do not see on the 75/15 unit that is factory installed.
I've searched for info on this, and the best I can find is that Victron says you should connect the ground screw to a chassis ground of the RV, but users are about equally split if it is necessary.
Electrically, it is not needed for the 100/20 to operate properly...but it is for safety if something malfunctions and voltage gets to the heatsink i guess.
Can a case ground like this be connected to the negative of the battery distribution block?
If not, does anyone know where the 2021 400 chassis ground point is?
Thanks in advance...
0 ·
I believe the controversy about the need for a separate ground of 12VDC circuit is that they are usually low amps and aren't a human safety issue (But can surely damage electronics, as you mention).
Hope this helps...
2019 320 Boondock Edge - Sold Jan 2022
Like I mentioned, I'd say the internet responses to this were about equally split on "ground it or you'll burn down your camper", and "why bother". So you are not alone in not having bothered.
I had seen (and forgotten) the link you sent - and it makes me disinclined to run a wire all the way from the far back to the tongue for this.
Thanks. I did see a number of posts discussing exactly that issue - that it isn't a real safety risk for a 12VDC circuit.
Do you know if connecting the case ground to the battery distribution box ground is viable? That must be wired to the grounding lug at the front of the camper, right?
But I would love to know if connecting the Victron case ground directly to the negative terminal of the battery distribution block isn't just as good (and is definitely easier).
@ChrisFix, to get back to your specific question, on my 2015 "320" the 12VDC negative bus near the converter is grounded to the chassis via one of its mounting screws (which is apparently driven through an aluminum frame member under the floor). Newer models feature a wire connecting the 12VDC negative terminal in the forward junction box with a nearby bonding screw on the frame.
Therefore, the battery negative, the negative leads from all 12VDC devices, the negative terminal in the forward junction box, the 12VDC negative bus, and the chassis are all interconnected. Theoretically, that suggests that is shouldn't matter where in that network you connect the ground, but I have a nagging feeling there is more to it than I am comprehending.
For lack of better understanding, I would probably connect to the chassis ground screw adjacent to the forward junction box, rather than directly to the negative battery terminal.
Thanks.
I've come to those same conclusions as well.
The 12VDC ground bus and the -12VDC of the battery each have a direct connection to the distribution box at the front of the trailer. And from that distribution box12VDC ground terminal, there is one wire connecting to the actual ground lug of the frame.
So both battery negative and the 12VDC bus have the exact same electron path, but I think if you get into the various codes, you're still not supposed to connect to the battery negative - and I honestly don't know why.
I need to pick up wire to run the case ground to the 12V bus bar...but it is already charging the batteries!
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
