The valves under the bed by the hot water tank - 320s 2018 - I've been trying to work with Alde/nucamp through emails. The valves in my TT don't turn/align with the ones in the back of the Alde manual. 4 of them turn / set differently. I've tried various combinations, trying to get hot water flowing in sink and shower to no avail. Anyone else have this issue, and how did you resolve it?
The mixing valve is set as per instructive videos. I've run 5+ gallons of water to purge any air in the system. The Alde panel is set per instructions, comments and videos on this forum. There are no apparent leaks in the lines.
Also, related to valves no doubt - how do i know if the hot water tank has water in it?
Thanks!
0 ·
Pictures of your valves will help us help you.
What happens when you set the valves like the manual? Close both hot and cold drain valves, open the hot and cold supply valves and leave the bypass closed.
What valve are you referring to as the “intake” valve?
If the handle is parallel to the pipe it's open. If perpendicular it's closed. That's how all those valves work.
The plumbers aren't always consistent when they install them, so yours may appear different than those in the photos.
Once you have the valves set as described by @pthomas745, you should be able to get water to your Alde hot water boiler/tank. Here are some instructions that I previously posted for filling the Alde tank (to answer your question re how you know the tank is full):
To fill your Alde hot water tank (if empty) when connected to water service at a campsite, or at home, connect your hose (from the campground pedestal or house spigot) to the outside water inlet on the trailer (on the driver's side of the trailer at the front end.) Turn on the water supply and then open the hot water valve at the kitchen sink to pull water into the hot water line and to fill the Alde tank. You don't need to open the hot water faucet valve much.........in fact, you don't want to open it too far because, when first filled, there will be air in the water line and Alde tank that will "sputter" out of the hot water faucet until the tank is full. You will know that the Alde tank is full when the sputtering stops and the water flows freely from the faucet. After the sputtering stops at the kitchen sink faucet, close it to stop the water flow. Then, you should also briefly open the hot and cold water valves at the indoor shower to pressurize/fill those water lines and remove any remaining air. Do the same thing for the cold water lines, including cold water faucet in the kitchen and the toilet flush valve.
If instead using water from the fresh water tank (via the water pump), and assuming you have water in the fresh water supply tank, the process is the same once you turn on the pump. However, remember that since the water will be pulled from the fresh water tank, the fresh water supply tank will be depleted by a little over two gallons to fill the Alde tank. If you want a full fresh water supply tank, in addition to a full hot water tank, then you will need to top off the fresh water supply tank.
is traveling and may be in and out of cell service. @pthomas745 will be back. Those two are much more qualified than myself on the Alde valve positions. Be patient and they will answer.
Turn the Alde bypass valve perpendicular (closed) and leave it there for camping. If you winterize with antifreeze, you open the valve and antifreeze flows from the cold water plumbing to the hot water plumbing, bypassing the Alde water tank. You also leave the bypass open when you sanitize to avoid getting bleach in the Alde water tank.
Also, you need to turn the valve marked with the red arrow so that it is perpendicular to the hot water (red) pipe. This valve is for the hot water drain, and should only be opened when you want to drain the hot water line (same is true for the cold water drain, which is the valve on the far right side of your photo.)
Your bypass valve is correctly set for using your water while camping (i.e., it is currently closed.) As @Sharon_is_SAM noted, even if that valve handle is pointing upward (12:00 position), it should still be closed. It just depends how the valve was originally installed. That is what may be what is confusing you about that particular valve.
The below photograph (not mine, but it has been posted in this forum several times and is accurate ) shows how your valves will be set when "winterizing", or sanitizing your trailer's water lines. What the photo shows is that when you close the hot and cold water valves, you stop water from flowing into and out of the Alde tank.
By simultaneously opening the "bypass" valve, the cold water (that can no longer flow to the Alde tank, because you have closed the cold water valve) will make a hard left first through the short piece of blue PEX piping, through the open bypass valve, then into the short piece of red PEX piping, and then (because the hot water valve is closed) will continue through the red PEX leading down toward the bottom of the photo - - - that pipe leads to the hot water side of your sink and shower. Essentially, what you are doing is "bypassing" the Alde hot water tank, because you don't want to send bleach (for sanitizing the water lines) or anti-freeze (for winterizing the water lines) to the Alde hot water tank, because those chemicals can damage the interior of the Alde tank. If you ever accidentally fail to bypass the Alde tank and those chemicals are allowed to flow into it, just do a good job of flushing out the Alde tank with water and you will be OK.
Good luck!
CORRECT VALVE SETTINGS FOR CAMPING MODE:
