I chose the white Aero Flow vent cover since they don't have a red one
. I installed it today, so now I can have the Fantastic Fan vent open any time I want.
No, that was in my driveway after dark last night.
I leave Tuesday for 12 days of camping, including the CRA. Then to Tearstock. Three weeks (almost) of camping.
Minnesota
Practicing to be a wanderer
Transitioned from 2014 T@B 320 CSS M@xx to 2020 T@B 320 CSS Boondock Lite
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
Minnesota
Even with it all of the ladder climbing it only took about an hour to install the AeroFlo by myself.
The smoked gray tint looked better on my Silver Shadow, too. This white looks better on the white body.
Bob, mine is a 2014. You do not have to drill into the roof, no matter what year. I didn't have to drill into the roof on my 2011 Silver Shadow. Trust me, you drill into the Fantastic Fan. Here's a quick walk-through, but be sure to read your insturctions.
You drill four 5/32" holes into the flange of the Fantastic Fan. Then you take four "L" shaped brackets, screw them into these holes, after putting a supplied bolt up through the bottom of the "L" bracket.
Then you lay the bottom half of the vent onto the 4 bolts, add two washers and a nut, tighten, and then attach the top part of the vent cover.
I did lay a thick padded quilt over the side of the T@B so I wouldn't damage her trim with my extention ladder laying up against one top. I used a step ladder on the other side.
But, you do not have to drill into the roof. You drill into the upright flange of the FF. Trust me
I have the smoke gray - doesn't block all the light like the black model or get too bright like the white.
PXLated, I can unscrew two screws and the top will hinge and can be removed. But I normally don't take a ladder tall enough to do that.
Martha in VT: '15 T@B CS-S Max H@ppy C@mper with '16 GMC Sierra 1500
2014 T@B-S
North Carolina
2015 T@b Max Q
https://www.amazon.com/dp/B000EDUTTK/ref=cm_sw_r_em_api_i_c_GcOiBbHV95CW8
