I have done a search here after this turned up yesterday in my less-than-two-years-old T@B 400. Heat has worked fine, but now unit comes on, makes flame sound for thirty seconds, cuts off, tries again (that's what it sounds like), then throws a Gas Failure. There is some warmth. So it's lighting but not staying lit.
Read some troubleshooting tips here and have done some:
- Reset on panel
- Unplug 12v from the Alde
- Turn off gas and sloooooooooooowly reopen valve like on my gas grill, which slows to trickle if you open it too fast
- Exhaust flue is clear and I even vaccumed it out.
- Soapy water test on regulator connections and Tee-intersection at rear. No bubbles.
The stove gas rings work fine. Full propane tank (although this started when tank was near empty -- I thought that's all it was at first).
One curious thing: With all the recent discussion of glycol, I checked my reservoir and it's sitting at Max. I have never touched the thing since purchase; never needed to because heat has always worked wonderfully. About to draw it down with a siphon tube. I don't see how that could be related, but ...
Thanks for any input. I emailed Alde and they have been less than helpful. ("$280 for a new circuit board and we don't have any anyway, have a nice day")
