Color of T@b trim
kiva
Member Posts: 4
Can the Tab trim be painted?
Yes. Best done by a auto body shop, but I believe some people have DIY’ed it with spray cans or hardware store grade paint sprayers.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Thank you
I painted my trim on my Dutchmen T@B using Krylon paint for plastic. It's done really well.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
@Mouseketab could you get good “cover” with 1 coat? Were you able to paint with the trim attached or did you remove it? Thanks.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
I removed the trim to paint it. I don't remember if it was one coat or two. I just lightly sprayed until I had full coverage.
Carol
MOUSE-KE-T@B
Harvest, AL -
X2Mouseketab said:I painted my trim on my Dutchmen T@B using Krylon paint for plastic. It's done really well.- Hash T@B Fun
I would mask and paint in place. Less chance of breaking it.
- Hash T@B Fun
Just an FYI, I have a Clamshell, so only the fenders, windows, and front handle trim. It was easy to remove and replace. Not sure I would have attempted all of the edge trim on the inside kitchen model.
Carol
MOUSE-KE-T@B
Harvest, AL -
Has anyone found a good Krylon match for the gray trim paint. Silver metallic is too metallic and too satin, needs more gloss…
@Kimball - did you see this thread?
https://tab-rv.vanillacommunity.com/discussion/3002/gray-trim-paint
- 916 Introductions
- 72 Teardrop Groups & Links
