How Can I Obtain a Link to a Comment?
Is there a foolproof way to obtain a link address to refer to a particular comment within a discussion topic, such that it will open the discussion at that spot without having to scroll to find the correct comment being referenced?
For example, I have found the following two links that reference the same discussion topic, but cannot find a link address that references my own comment within that topic..
Is this possible?
    The only way I've found to do this is to use the extended search feature to find your own comments within a particular discussion or topic. For example, I found this by searching Keyword: Alde and Author: ScottG.
    https://tab-rv.vanillacommunity.com/discussion/comment/63156#Comment_63156
    It's more cumbersome than I typically care to bother with. If you figure out something easier I'm all ears.
  • Marceline
    Marceline Member Posts: 1,779
    edited September 2021
    If you click on the timestamp for the comment, it will open a window with that particular comment at the top. Then you can copy the link to that window, which will show the comment number.
    https://tab-rv.vanillacommunity.com/discussion/comment/116945/#Comment_116945
    Genious--and so elegantly simple I would never have figured that out on my own! Thanks, @Marceline.
    In the Today I Learned file!  Thanks @Marceline !
  • Marceline
    I should've said that you can simply right click on the timestamp and select "copy link."
    But you get the idea...
  • BrianZ
    BrianZ Member Posts: 1,770
    Wow, thanks @Marceline, I can't believe I've never noticed that before!  I do tend to find a complicated way before what's staring me right in the face!  That should teach me not to ignore the blue text of a hyperlink.  Now, if I can just remember where I put those glasses I'm wearing. ;)
    Or, on my Android phone, long press on the blue timestamp for a menu of options, including "Copy link address", for pasting elsewhere to save...
  • BrianZ
    Thank you, @ScottG, for sharing your method of combining keyword & author in a search to get a link to a specific comment.  While it's not as direct & simple as @Marceline's method, it does have the added advantage of pulling up other closely related or repeated comments that could be helpful.
