How Can I Obtain a Link to a Comment?
BrianZ
Member Posts: 1,770
Is there a foolproof way to obtain a link address to refer to a particular comment within a discussion topic, such that it will open the discussion at that spot without having to scroll to find the correct comment being referenced?
For example, I have found the following two links that reference the same discussion topic, but cannot find a link address that references my own comment within that topic..
Is this possible?
-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods
The only way I've found to do this is to use the extended search feature to find your own comments within a particular discussion or topic. For example, I found this by searching Keyword: Alde and Author: ScottG.
https://tab-rv.vanillacommunity.com/discussion/comment/63156#Comment_63156
It's more cumbersome than I typically care to bother with. If you figure out something easier I'm all ears.2015 T@B Max S (320)
If you click on the timestamp for the comment, it will open a window with that particular comment at the top. Then you can copy the link to that window, which will show the comment number.
https://tab-rv.vanillacommunity.com/discussion/comment/116945/#Comment_116945
Genious--and so elegantly simple I would never have figured that out on my own! Thanks, @Marceline.
I should've said that you can simply right click on the timestamp and select "copy link."
But you get the idea...San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Wow, thanks @Marceline, I can't believe I've never noticed that before! I do tend to find a complicated way before what's staring me right in the face! That should teach me not to ignore the blue text of a hyperlink. Now, if I can just remember where I put those glasses I'm wearing.
Or, on my Android phone, long press on the blue timestamp for a menu of options, including "Copy link address", for pasting elsewhere to save...
Thank you, @ScottG, for sharing your method of combining keyword & author in a search to get a link to a specific comment. While it's not as direct & simple as @Marceline's method, it does have the added advantage of pulling up other closely related or repeated comments that could be helpful.-Brian in Chester, Virginia
