Hello all! Owned a 2006 Dutchman T@b for over 5 years now, and lurked on the forum for years getting ideas for modifications and help with certain issues. I've read everything I can on this, but can't find the answer: will the front aluminum storage platform that now is standard on the 320 Boondock (and formerly on the Outback) compatible with the Dutchman/Al-Ko frame? I'm not sure if the front tongue angles/dimensions ever changed after the frames were provided by Dexter rather than Al-Ko (I am aware that Dexter owns Al-Ko). I'd like to add a front platform to my trailer and would love the standard Boondock platform if it fits. It may even come down to measuring it, if that is something that can easily be done. Thanks in advance!
0 ·
I think you are going to find, it might not fit, as they are two different frames, with different angles from what I understand.
Also, you need to determine if the Dutchman frame at the tongue can support the additional weight. A call to nüCamp customer support might get you the answer.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
ive been looking for a couple years for a box to fit.
will soon start looking for a fabricator. I am in CA.
https://tab-rv.vanillacommunity.com/discussion/13644/tongue-box/p1
I saw several T@bs on my lengthy trip; some with the Outback/Boondock style platform and each seemed like there was a struggle to decide how to pack items on each platform. One had small diamond plate boxes on each side, which didn't look spacious or cost effective. Another had plastic bins on each side which looked good, but again, limited in room. Very, very happy with my final product; can't thank you enough for how thorough your write up was.
