3 way fridge 12V voltage level - SOLVED
webers3webers3 Member Posts: 421
Removed the 3 way fridge and wanted to use the 12v line that went to the 3 way fridge to power the new 12v  fridge but when I measured the voltage on the 12v line it shows 11.3v even though the battery voltage is at 12.7v. I measured the voltage at the battery and at one of the 12v outlets inside to verify the 12.7v. Any explanation why the voltage on the fridge line is low?
