Removed the 3 way fridge and wanted to use the 12v line that went to the 3 way fridge to power the new 12v fridge but when I measured the voltage on the 12v line it shows 11.3v even though the battery voltage is at 12.7v. I measured the voltage at the battery and at one of the 12v outlets inside to verify the 12.7v. Any explanation why the voltage on the fridge line is low?
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
0 ·
Brad
Concord, NC
Brad
Concord, NC
That phantom 11.3v was probably due to the tiny current which powers the “red fuse is blown” LED in the WFCO. The LED is usually shorted out by the fuse, but when that’s blown a trickle current runs through the light and then to the fridge or other load.
