Realized I had no brake/signal lights. Happened to be near a TAB dealer on a trip thru Ukiah, CA so I took a chance they could look at my rig. Service guy got under the rear bumper and saw a pulled wire because there was too much tension on the wires and he said we must have gone thru a driveway and the plug got pulled rearwards. Got the lights working but he says Uhaul wired up only only 4 of the 7 wires to the plug and that because of that I had no power to the 320 there were no trailer brakes and the batteries (2 - 12 v.) went dead running the refrigerator. Having full hookups in the KOA we thought the batteries would charge during the 48 hrs. we camped. No such luck.
Right after getting the brake controller and trailer plug installed I pulled trailer out of the back yard and noticed (I thought) that the trailer controller was set too high and brakes were grabbing too hard. I turned it down to 15 and the grabbing stopped. 2 years later after getting brake/signal working I cannot tell if trailer brakes are working or not. Any advice?
2-years ago the brake controller was installed and appeared to work correctly.
You selected a 15% brake force setting at that time.
In the recent past your 7-pin wiring was damaged, then repaired.
Now you are not sure the Brake Controller is working
Does your Controller have any error codes?
E1 no trailer, or E2 blue wire short.
Have you tried your braking test with Controller set well above 15%?
You have a couple of options for additional troubleshooting.
These are in no special order and are ideas/suggestions to consider.
1. With TV connected, jack one trailer wheel off the ground.
You should be able to rotate wheel . . . will it rotate when TV brakes are on.
2. The Reliance is a Time Based Brake Controller.
There is a short time delay between pressing the TV brake pedal and when voltage appears
on the 7-pin "blue wire". Also the voltage value will change with the 5-100 setting of the Controller.
At 100 you should be able to read 12VDC on the blue wire.
At 50 you should see something lower, most likely near 6VDC
Note: Might have to measure at T@B junction box as Controller might need "to see" the trailer
lights load so the E1 error clears. However, it might still output brake voltage when E1 is displayed.
If either [1] or [2] indicates the brakes are engaging.
Then consider adjusting the brake shoes or increasing the Controller setting.
If brakes are not engaging 7-Pin wiring should be checked again.
Or controller has failed.
As far as shore power not working, that is a totally separate and non related issue to the trailer to tow vehicle wiring.
