Best way to clean grey water tank?
gkillmaster
I can't seem to find this in the manual. What is the best way to make sure the grey water tank is clean enough when storing for awhile? Should I use any bleach?
Thanks for any tips on this!
Greg K.
Greg K.
Honestly, I leave mine empty. If there is an odor, I’ll put a scoop full of Happy Camper and some fresh water to get rid of the odor.I don’t use bleach in my gray tank as some dump stations use a septic system for the dump station and bleach kills the helpful bacteria.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3 -
Thank you!!0
Hi Verna, do you also leave the fresh water tank full say if you are going to not use it for several weeks?Verna said:Honestly, I leave mine empty. If there is an odor, I’ll put a scoop full of Happy Camper and some fresh water to get rid of the odor.I don’t use bleach in my gray tank as some dump stations use a septic system for the dump station and bleach kills the helpful bacteria.0 -
No, I drain the fresh water tank. Too much “bad stuff” can grown in those tanks. In fact, I had a funky smell like sulfur in well water after coming back from out West and I sterilized the tank for the third time this year.Verna, Columbus, IN
Thanks again!0
Make sure that you have the P traps filled with Antifreeze and then close the sink drain and cover the shower drain to prevent evaporative loss. Then, no odors will creep back into your cabin.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio6
Thanks, @Tundra57. I almost emptied the fresh water on my last camping trip, but I added 5 more gallons. I did not smell the sulfur odor, so maybe it won’t take me as long to get rid of the odor. Fingers crossed! (I paid extra for my water softening system at home so I don’t have the sulfur smell as I really hate that odor!)Verna, Columbus, IN
I tried emptying my fresh water after our trip and even though the water stopped draining, the fresh water tank display stayed at 19%. I'm assuming maybe the indicator is not accurate. I drained it on level ground.0
@gkillmaster drain is not at the bottomYou need a left slope sideways. Filler side down. Even then still some in. There are articles on this0
@gkillmaster, I agree with @Tundra57. Your tank sensors may well be off a little bit, but regardless the FW system is not a particularly good design. The FW tank has no slope and tend to develop bulges in one direction or the other. The vent system is also sketchy. This impedes complete emptying of the tank by either the drain valve or the pump--as well as filling the tank--unless additional T@B acrobatics are performed. It's a tight fit and just one of those quirks we learn to work around 'cause we love or T@Bs. :-)
For those with newer T@Bs having the plastic underbelly cover, here's a photo of the magic bits hidden up between the frame rails.
And the models with the Nautilus have the drain at the rear of the tank=trailer, so tongue up to more completely empty.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
And the TaB400 tank is completely different, with drain coming from the front side, next to the wheel, and fill and pump intake lines come out the top of the tank, not the side or bottom, and directly through the trailer floor. Each series of TaB’s is different, depending on when it was made.
Good points. I've edited my previous post. It's getting hard for me to keep up with everything that has changed since 2015... :-/2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x40
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
