Anyone Have the Specs on the converter in the T@B 400 2022 Model?
[Deleted User][Deleted User] Posts: 834
After paying $700 to upgrade the converter in my 2019 T@B 400 just this past March, I just sold the T@B! I never even got to use the new converter while boondocking on generator.
Anyway!, I have a 2022 on order and I do see the converter/circuit breaker box is mid trailer now (my original one was at the front) and I know that was one of the reasons we were not getting a quick charge with the converters that were mounted so far from the batteries.
I'm wondering if the converter/breaker being close to the batteries now in 2021/22 models, does this help much, or should I tell my dealer to install another Progressive Dynamics converter before I even pick it up?
Thanks
    My 2019 had the factory location under the wardrobe closest, so a very short run to the battery, if that is when the 2022 is now, then I think you will be fine. I believe the 2022 also has a Lithium setting, if so, I think I would see how that works rather than spending money early on.
    edited October 2021
    Yes, the converter is on the opposite side on the 2022 model TaB400, under the center galley cabinet (occupies a former galley locker spot), so still a close run the the batteries under the center bunk area.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,885
    @TabbyShack  - this is from @dbremmer who has a 2022 400.  “I checked the Converter (AC to DC).  It is a WFCO Model WF-8735LiS.  The Converter output is listed as 14.6 VDC 32.5 A (Li), and 13.6 VDC 35A (LA).  I found the small switch at the panel top-right that switches between Li and LA.”
  • RFraerRFraer Member Posts: 92
    It's not the converter to determines the voltage drop it's the wire gauge and wire length. I have 12 ft of 4AWG wire to the battery and see a 0.18v drop, or 1.5%, up to 3% is acceptable. If 2AWG wire was used there would have been a 0.9% drop. If you want to upgrade change the wire size not the converter.
