Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Faucet Replacement - Tab 320 2021
elbolillo
Member Posts: 549
The faucet that came in our Tab 320 2021 was different than what was shown in the brochure and after a number of trips this summer we decided it left a lot to be desired and we changed it out. This is a huge upgrade in our opinion that makes the sink and faucet so much more usable. This is the replacement faucet: https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Install was a breeze and now the faucet swivels, has a pull-out sprayer, and both a spray and aerated stream function. This should be standard equipment on the Tab.
@elbolillo Looks really good, no interference issues with the blind or screen?
2021 T@B320 S - 2013 Ridgeline - Ont. Can
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!” Dr. Hunter S. Thompson
Yes...look great! Did you have to make any modifications to the hole through the counter?
REALLY like the concept of a pull out spray nozzle and the swivel. Great find @elbolillo
2019 320 Boondock Edge - Sold Jan 2022 -
No modifications were required. Took out the old faucet and replaced with the new one in about 15 min. Easy peasy. Much better faucet!!!Basil48192 said:Yes...look great! Did you have to make any modifications to the hole through the counter?_____________________________________________________
Ken / 2023 Tab 400 “La Bolita” (31,000+ miles) / 2024 Toyota Sequoia -
No issues at all with clearance.Rodent77 said:@elbolillo Looks really good, no interference issues with the blind or screen?_____________________________________________________
Is the hose long enough to pass through the window?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Yes it should be long enough to go through the window. Although I have the weight that goes on the hose set so that it only pulls out about 10”.Sharon_is_SAM said:Is the hose long enough to pass through the window?_____________________________________________________
Well, if you can slide the weight back maybe it can double as an outdoor shower!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Any hints on unscrewing and removing the old faucet?
2021 320S BD
2020 V6 Chevy Colorado -
We installed the same faucet but did not use the weight. Haven’t had a problem pushing the hose back in. I did use it for doing dishes in a collapsible tub out on the tongue box. The button for stopping flow is spring loaded. If you’re not holding it in the water continues to flow. Have to figure a way to stop the flow and free up hands without reaching in the window.Stockton, New Jersey
60,865 camping miles through the end of 2025 -
elbolillo said:The faucet that came in our Tab 320 2021 was different than what was shown in the brochure and after a number of trips this summer we decided it left a lot to be desired and we changed it out. This is a huge upgrade in our opinion that makes the sink and faucet so much more usable. This is the replacement faucet: https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Thanks to your recommendation I just installed the same faucet. WOW it truly is a huge upgrade! Thank you!! Jordanelbolillo said:The faucet that came in our Tab 320 2021 was different than what was shown in the brochure and after a number of trips this summer we decided it left a lot to be desired and we changed it out. This is a huge upgrade in our opinion that makes the sink and faucet so much more usable. This is the replacement faucet: https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California -
@elbolillo the 266 right? not the other numbers? did you see it comes in black-wow!!!
Correct. 266KismetKrush said:@elbolillo the 266 right? not the other numbers? did you see it comes in black-wow!!!_____________________________________________________
How did you connect those brass connectors to the original Tab blue and red connections?
Nevermind, I figured it out. Pretty easy. Thanks for posting.
- 135 Help - Computer & System
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
