Faucet Replacement - Tab 320 2021
The faucet that came in our Tab 320 2021 was different than what was shown in the brochure and after a number of trips this summer we decided it left a lot to be desired and we changed it out. This is a huge upgrade in our opinion that makes the sink and faucet so much more usable. This is the replacement faucet: https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Install was a breeze and now the faucet swivels, has a pull-out sprayer, and both a spray and aerated stream function. This should be standard equipment on the Tab.
  • Rodent77
    Rodent77 Member Posts: 81
    @elbolillo Looks really good, no interference issues with the blind or screen?
    2021 T@B320 S - 2013 Ridgeline - Ont. Can
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!”  Dr. Hunter S. Thompson
  • Basil48192
    Basil48192 Member Posts: 437
    Yes...look great!  Did you have to make any modifications to the hole through the counter?
  • CrabTab
    CrabTab Member Posts: 457
    REALLY like the concept of a pull out spray nozzle and the swivel. Great find @elbolillo
    2019 320 Boondock Edge
     - Sold Jan 2022
  • elbolillo
    elbolillo Member Posts: 560
    No modifications were required. Took out the old faucet and replaced with the new one in about 15 min. Easy peasy. Much better faucet!!!
  • elbolillo
    No issues at all with clearance.
    Is the hose long enough to pass through the window?
  • elbolillo
    Yes it should be long enough to go through the window. Although I have the weight that goes on the hose set so that it only pulls out about 10”.
  • elbolillo
    Here are a couple more photos.
    Well, if you can slide the weight back maybe it can double as an outdoor shower!
  • edaletaylor
    edaletaylor Member Posts: 12
    Any hints on unscrewing and removing the old faucet?
  • Mobean
    Mobean Member Posts: 74
    you need a special faucet wrench.
    2021 320S BD
    2020 V6 Chevy Colorado
  • AnOldUR
    AnOldUR Member Posts: 1,737
    We installed the same faucet but did not use the weight. Haven’t had a problem pushing the hose back in. I did use it for doing dishes in a collapsible tub out on the tongue box. The button for stopping flow is spring loaded. If you’re not holding it in the water continues to flow. Have to figure a way to stop the flow and free up hands without reaching in the window.
  • jbajor
    jbajor Member Posts: 233
    Thanks to your recommendation I just installed the same faucet.  WOW it truly is a huge upgrade!  Thank you!!  Jordan
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • KismetKrush
    KismetKrush Member Posts: 29
    @elbolillo the 266 right? not the other numbers? did you see it comes in black-wow!!!
  • elbolillo
    Correct. 266
  • Iamoscardiaz
    Iamoscardiaz Member Posts: 2
    How did you connect those brass connectors to the original Tab blue and red connections?
  • Iamoscardiaz
    Nevermind, I figured it out. Pretty easy. Thanks for posting.
