Our 2020 320S has a cigarette lighter type outlet in the back by the bed on the drivers side. While trying to find out what each of the 12V fuses provided protection for, I removed every fuse. None of the fuses cut power to that 12V cigarette outlet. Anyone know why or have an explanation?
edit to add: To see if there was power there, I plugged in a 12V device that had an LED pilot light on the plug. That light never went out. Could there be residual power keeping the light on even after the fuse is removed?
Fuse keeps burning out
TV 2022 Highlander
The short version (pulled from the 'Fuse keeps burning out' thread) is your LED Pilot light is 'seeing' the available current used to light the Power Center 'Fuse Bad' LED.
Jeff & Amy
