Is this the "On/Off" control for the AIMS inverters in the 400?  Or some thing that looks like it? Can anyone explain for me...how it works?  What the blinky lights mean?  If I was looking at this in the trailer, how would I know the inverter is off?  Completely off?  The manuals for the AIMS inverters just say "here is the remote". I cannot find anywhere a real description of what I'm looking at and how exactly it works.  ( I have some guesses......).
You would know if it were on by the LED underneath the Inverter/AC Mode, the LED will either be green for Inverter Mode or yellow for AC Mode, or not illuminated if it is turned off.
Brad
Concord, NC
In all cases, the inverter needs to be turned on from the control panel to work, once turned on, (with units having the shore power transfer) the inverter will provide power to the outlets from shore power when connected. Inverter turned off, no power to the inverter outlets in any situation. Not sure how a 2021 or 2022 TaB inverter is setup.
Mine is a 2018, so same as 2019, with the inverter outlet at the foot of the bunk under the end galley ext counter. It works only on battery, with its control panel next to it. It does not work on shore power, wish it did.
