I haven't seen much discussion on keeping Lithium batteries warm (enough) in the winter and I'd be interested in knowing what others are doing. I bought an 40W AC-powered VivoSun seed germination heat pad a few weeks ago but wasn't sure how well it would work. I finally got the chance to see last night as it got down to 6 F. -- the under-bed battery compartment was at a toasty 46 F in the morning. I'm assuming now that I'll be OK at 10 or 20+ below - the goal being to keep the battery above -4 F. An interesting thought is that if the mat works that well, you could keep the battery warm enough using the inverter to power it, and we could use it when winter camping. Anybody using their LiFePos in the winter, and how do you warm them?
2019 T@B 400 (for sale)
2017 Highlander Limited
0 ·
I just got back from a three week trip to the TX, AZ area. I have three SOK LiFePos Batteries located under the bed. I spent a night at a Walmart in Fort Stockton TX. During the night there was high winds (20-25 MPH) and the temperature when I got up was 20F. When I tried to use the sink there was no water. Apparently the outlet line from the fresh water tank had frozen. I then checked the battery temperature through my Victron VE.Bus Smart Dongle that is attached to one of the batteries, it indicated 80F at the battery. The Alde heater that is in the compartment next to the batteries kept them toasty, I am not going to be adding a battery heater. I will be looking into a tank heater but it will be 12v. Luckily there was no damage to the water tank line. I concluded that my tank froze because of the high winds that got under the floor through the large frame holes. Later in the trip I encountered low temps again but no wind and did not have a water freezing issue. I will also be looking into a temporary way to plug the frame hole during cold temperatures.
"Temperatures below -4°F (-20°C) will cause the electrolyte to freeze which will cause permanent damage to the batteries if it does not kill them entirely. If storage temperatures will go below -4°F then you will need to heat the batteries to above -4°F to prevent damage to the battery. There is no exception to this."
I’m still on the side of “If you’re going to go to the effort of heating, may as well make sure you can charge too,” which is why I’m leaning towards self-heating LiFePo4 instead. But your solution should at least protect the batteries from damage.
With that said, if I were buying batteries now, I would spring for the self heating ones, both Renogy and Battleborn have them at about $100 upcharge per battery. I’m trying to determine if it is worth adding some sort of heating to my battery compartment since we do winter camp and my batteries are not self heating… ☹️
Poughquag, NY
