We got our new 2022 T@B400 and are very happy with it. When we ordered it, I had nuCamp install a larger inverter (2000W), and was expecting that all 110V outlets would be powered by it when not on shore power and using the inverter. However, only the outlet in the cubby by the bed, and the one for the TV are active, the other ones only work when on shore power. How difficult would it be to rewire so that all outlets are powered by the inverter when on battery? Is it as simple as "disconnect from WFCO center and connect to inverter", or what needs to be done?
This is not because I want to use all outlets at the same time, but I need the ability to plug in where it is most convenient, rather than running an extension cord through the entire camper from the bed cubby to the dinette, for example. And if I really want to use the microwave for 30s to warm something up, I want that ability, too (not planning to use it for heating whole meals). We have a 300Ah Li battery, so we're not that short on battery juice.
All pointers and explanations are greatly appreciated.
Brad
Concord, NC
2017 Highlander Limited
If you are not familiar with marine/RV electrical systems, get a good RV service department to make this change for you. The trailer you save, may be your own.
It’s not that difficult but you need a basic understanding of electrical wiring both AC & DC. I am not sure why all your outlets are not working. Are you turning on your inverter? And does your 2K inverter have a transfer switch?
NuCamp wires the inverter after the WFCO center because it is not meant to power the entire camper. When you upgrading batteries and inverters to power the air conditioner and microwave generally the inverter is moved to before the WFCO center so the inverter can power the MAIN AC bus which is the top 30 amp breaker in the power center. I don’t know which 2k inverter was used on your 400 but to me 2000 watts to small to power the AC power bus in the 400.
My understanding is that the 120v outlets are all on the same circuit, why in your case only two outlets work when the inverter is running is puzzling. Unfortunately the Microwave is on a different circuit then the inverter so no microwave when boondocking. You may have to take it back to your dealer so they can trace the wiring.
Also, the inverter would not power the Fridge on AC (too large a draw) and runnjng the AC buss on the WaCo, would kick the fridge to AC, Same for the FoolCar AC. So you are going to need a separate bus for the AC outlets you want powered by the Inverter. You can not power the WaCo AC buss from the 2K watt inverter, it is not big enough as previously pointed out by RFraer.
As I previously mentioned, a 2K inverter will not run the factory nüCamp installed microwave wave either. I tried powering a smaller (portable) microwave with a 1800 watt AMIS inverter with a 2K surge, and it ran the microwave for only 15-20 seconds and then shut off, a cup of water in the microwave was not even hot, just slightly warm. You need a 3K inverter (which requires 300 amps of battery power) to run the larger Microwave installed in the TaB.
2025 Toyota Tundra / Nashville, TN
I might go whole house later but first I will confirm endurance and heat parameters in the intended installation location for inverter.
if you do go whole house the chief concern is safely disconnecting the power converter so that the ac/dc battery charger is always disabled via interlock when inverter is running.
go power ts-30 has a diagram of this setup with a “fuse” but I’m using a simpler setup that is also smaller - Wfco t-30. The larger model would have some location issues in a tiny 320.
Let me add the only appliance we have that go over 999 watts are a hairdryer and the Alde. We have managed to find toaster oven, coffee machine and instant pot below 1k.
