Can anyone tell me where the disconnected cable (with 30 amp fuse goes in this picture) positive or negative post ? Thank you in advance for any help.... 2017 T@B CSS
That does indeed look like a negative symbol! I just looked at three deep cycle lead acid batteries that I have in the garage and they all have the negative terminal on the right side of the battery if you look at it the way it is in the picture. I would definitely trace the wires and see where they come from before I would proceed.
@pthomas745 if you ignore the orientation of the label and look at the location of the round posts @WayneW is still correct. Some car batteries have the terminals switched (often indicated by an "R" suffix) but I've never seen that on RV deep cycle style batteries.
2017 F-150
Coeur d'Alene, Idaho
