Lagun Table Outside Bracket Install
I have a 2018 T@B 320 Outback that I'm going to add the Lagun table mount to the outside of the trailer.  I plan to put it next to the horizontal 120V outlets behind the wheel well.
I have the bracket and ordered/received the plastic spacer block from nuCamp.  How have others supported the bracket on the inside of the trailer?  I have seen a picture where someone put the board that came with the bracket kit against the inside of the azdel panel under the rear seat.  I'm concerned that mounting that way puts most of the load on the inside and outside panels of the azdel foam sandwich.  I was thinking about adding plywood (glue/screw) that sits on the interior plywood panel under the seat so that the load will rest on the trailer floor.
It would be helpful if someone could post a picture of how the factory installed bracket is supported on the inside of the trailer under the seat on the newer models.
2022 T@B 320S Boondock
    This is how ours was mounted on our CSS, I think by our dealer.
  • Denny16
    Denny16 Member Posts: 5,430
    If you get the Lagun mount for Lagun, it comes with a backing block and two poly pads.  Use rhenPly pads on the outside and add the backing block on the inside against the plywood siding if the TaB.  This will give you a solid mounting for the table, which can add some flexing force to the trailer side.
  • Tross2023
    Tross2023 Member Posts: 77
    So, looking to do this Lagun Mount modification, do you know the part number to order it from the dealer?
    please and thanks
    Tom
    2024 Hyundai Santa Cruz and 2018 T@B 320S
  • 1963122
    1963122 Member Posts: 52
    Hi Tom,
     I'll see if I can find the invoice. Had it installed at NuCamp
  • Tross2023
    Thanks, very kind of you
    pthomas745 Administrator, Moderator Posts: 4,587
    Lagun USA will sell it to you directly.  I tried getting a link a few minutes ago, and got a web error, but just Google "Lagun USA" and you should (hopefully!) get there.
  • Tross2023
    Great Idea, thanks.
  • SLJ
    SLJ Member Posts: 650
    edited June 2023
    https://www.lagunusa.com/product/bracket-w-hardware-kit
    You will most likely need longer bolts to go through the outside wall and back plate than come with the kit.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Marceline
    Marceline Member Posts: 1,756
    Is that just the T@B laminate wall or is there some kind of backing board there?
    @Marceline - no backer, just the original equipment supplied by Lagun.  This was placed by the dealer.
  • Marceline
    Maybe I'm a little overcautious, but I'd be uncomfortable with just the fender washers. It looks like those bolts are plenty long, so it would be easy to add a backer without even taking off the bracket. It would help distribute the load of any weight put on the table across a bigger surface area of the wall.
