Lagun Table Outside Bracket Install
stepheng
I have a 2018 T@B 320 Outback that I'm going to add the Lagun table
mount to the outside of the trailer. I plan to put it next to the
horizontal 120V outlets behind the wheel well.
I
have the bracket and ordered/received the plastic spacer block from nuCamp. How have others supported the bracket on the inside of the trailer? I have seen a
picture where someone put the board that came with the bracket kit
against the inside of the azdel panel under the rear seat. I'm
concerned that mounting that way puts most of the load on the inside and
outside panels of the azdel foam sandwich. I was thinking about adding
plywood (glue/screw) that sits on the interior plywood panel under the
seat so that the load will rest on the trailer floor.
It would be helpful if someone could post a picture of how the factory
installed bracket is supported on the inside of the trailer under the
seat on the newer models.
2022 T@B 320S Boondock
This is how ours was mounted on our CSS, I think by our dealer.
If you get the Lagun mount for Lagun, it comes with a backing block and two poly pads. Use rhenPly pads on the outside and add the backing block on the inside against the plywood siding if the TaB. This will give you a solid mounting for the table, which can add some flexing force to the trailer side.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.2 -
So, looking to do this Lagun Mount modification, do you know the part number to order it from the dealer?
please and thanks
Tom
2024 Hyundai Santa Cruz and 2018 T@B 320S0 -
Hi Tom,
I'll see if I can find the invoice. Had it installed at NuCamp1 -
Thanks, very kind of you2024 Hyundai Santa Cruz and 2018 T@B 320S0
Lagun USA will sell it to you directly. I tried getting a link a few minutes ago, and got a web error, but just Google "Lagun USA" and you should (hopefully!) get there.
Towed by 2014 Touareg TDi1 -
Great Idea, thanks.2024 Hyundai Santa Cruz and 2018 T@B 320S0
https://www.lagunusa.com/product/bracket-w-hardware-kit
You will most likely need longer bolts to go through the outside wall and back plate than come with the kit.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
Is that just the T@B laminate wall or is there some kind of backing board there?Sharon_is_SAM said:This is how ours was mounted on our CSS, I think by our dealer.
@Marceline - no backer, just the original equipment supplied by Lagun. This was placed by the dealer.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Maybe I'm a little overcautious, but I'd be uncomfortable with just the fender washers. It looks like those bolts are plenty long, so it would be easy to add a backer without even taking off the bracket. It would help distribute the load of any weight put on the table across a bigger surface area of the wall.Sharon_is_SAM said:@Marceline - no backer, just the original equipment supplied by Lagun. This was placed by the dealer.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
4
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
