I used to think bus bars were often for those obsessed with neatness and unnecessary for just a few connections. However, after adding solar power, a battery monitor and a charger to our electrical system, our battery now looks like this..
I expect this tangle of wires with no less than 3 fuses attached will make things a bit unwieldy when it comes to battery maintenance & cleaning. Plus, there are a couple more negative post connections already moved to the monitor shunt in addition to these.
So, in anticipation of cleaning up this mess, I am making plans to add buss bars inside a separate junction box, and move most of these wires & fuses there.
I got two of these mini bus bars, a pair of 2-ft 6-gauge cables, and this junction box to house all the extra battery connections.
● Blue Sea Systems 2315 MiniBus 100...
https://www.amazon.com/dp/B000OTJ8A0● ONLINE LED STORE 7-Port Trailer...
https://www.amazon.com/dp/B07G8S9ZCB● 6 AWG 6 Gauge Single Black 2 feet...
https://www.amazon.com/dp/B0721GBGGL● 6 AWG 6 Gauge Single Red 2 feet...
https://www.amazon.com/dp/B072MWHC1TOur tub has gotten quite full with all the additions, so this is the only space left..
There is already a similar junction box holding the shunt wiring for the battery monitor, which I plan to reposition a bit to the left to make room for a second box..
I plan to use some metal brackets to hang them as shown by this digital clone, the only way I could find to fit them both close to the battery box. I'll try to fit the fuses inside the box too.
Finally, here is my wiring plan showing how all three components will be rewired.
I drew in the new wire connections at the bus bars, each keyed to a number label on the existing old connection locations..
The blue connector (4) on the battery pos terminal is the battery temp sensor/shunt power lead, which will remain on the battery, the only other battery connection besides the two 6G black & red cables from the shunt/buss bar boxes.
(for size reference, I put a 6" white ruler inside the bus bar box, but the 3 photos in this composite are not shown at the same scale)
I may not actually get this project done until after warmer weather has returned, when those wires will not be so stiff & easier to reroute. Please let me know if you see any issues with this setup, as I have plenty of time to make changes.
Adventures: 51 Nights: 322 Towing Miles 41,200+
Unfortunately, I could not find any other place to mount the junction box holding the bus bars, as @MuttonChops had suggested. Since this new box is a bit larger than the one holding the monitor shunt, I had to mount it at an angle to fit it in.
The shunt box no longer has a bunch of battery negative wires connected to the load side (bottom terminal) of the shunt; as these have been moved to the negative bus bar in the newly added junction box, and replaced by a new 6G cable to that bus bar.
This new junction box holds all the (+) and (-) cables previously connected to the battery, including the three labeled fuses. I took this photo before replacing the two plastic protective caps that snap over the two rows of bus bar terminals.
With regard to the issue @MuttonChops raised about having to unscrew the box top to access fuses, I realized that both the charger & solar lines have pigtail ends hanging inside the tub, so I could easily check the integrity of both fuses simultaneously without opening the box, by connecting a multimeter to their positive ends & performing a continuity test. If it failed, then at least one of the fuses may be bad.
Not sure if there is an equivalent shortcut for the trailer fuse, though I would expect there would normally be a higher index of suspicion involved with the need to check that trailer line fuse (if one needs to check it, then it is likely bad?).
So, here's the difference the new junction box with bus bars makes at the battery.
It would have been just the two big cables remaining, except the battery monitor has a battery temperature sensor (blue connector) at the positive terminal, a line which also powers the monitor. This will make battery maintenance & clean up a whole lot easier & with less exposure of fuses to corrosion.
Final test of wiring showing two cell phone displays of the battery monitor app connection via wireless bluetooth connection with house power off, then on. Everything appears to be working normally.
Without AC power hookup, the monitor display at left correctly shows a fully charged voltage with a negative 200 milliamp current consumption from background trailer electronics that would drain the battery in about 10 days at 57°F. With power reconnected, the typical converter float charge voltage of 13.6V & 1 amp positive charge current is displayed.
This will typically drop back to a 13.2V trickle charge after 2-3 days..
I enjoy sharing my projects, and it's especially nice to hear when someone finds it useful.
Battery switch must be on, then..
To check the trailer fuse inside the bus bar box without opening it, perform another continuity test by connecting one probe to one of the same positive pigtails (charger or solar) connected to the positive bus bar. Then, connect the other test probe to the 12V positive connector inside the trailer's 7-way plug (top left terminal socket in the plug)..
If it beeps positive, then both fuses on those lines inside the bus bar box are good.
So, no need to open the box to check any of the fuses, and a continuity test is better than a visual inspection anyway!
- "Optimize Current Flow: the performance of a busbar can be increased by attaching the primary feed wire to the center of the busbar. The performance can be further increased by first attaching the primary feed wire followed by the highest load wire to the same terminal. This will allow the current to be carried by the large cables and avoid sending all of the current through the busbar. Although this will improve the performance of the busbar, it does not change the actual ampacity rating of the busbar and should not be used when comparing one busbar to another.
- Increase Voltage Capacity: Most busbars have both an amperage and voltage rating. Higher voltage can be achieved by:
- Increasing the creepage distance, which is the distance from a busbar mounting fastener to a grounded surface like a firewall. Creepage distance directly impacts the voltage rating of the busbar. Insulating the base and using insulating fasteners rather than conductive fasteners will significantly increase the safe operating voltage of a bus bar. The insulating system including the creepage distance has to prevent failure in the event of transients and surges in voltage.
- Managing the buildup of corrosion will significantly improve the safety and service life of a busbar. No exposed busbar can be expected to operate safely with a live connection in a wet location. An exception would be busbars used for lightening protection and grounding systems."
The bolded points are ones I applied, in addition to trying to place those cables typically carrying higher currents on terminals adjacent to the main battery cable terminal.I've always wondered about the safety of bus bars I've seen mounted in exposed areas, so the second highlighted point seems to validate my concern & reasons for installing inside a water-resistant box. Probably should still use some of the waterproofing goop I used on my shunt board on all these terminal connectors that may still be exposed to humidity & condensation.
The shunt is part of my installed battery monitor (Victron BMV712). It's not required for using bus bars, so without a shunt/battery monitor, the main negative cable from the neg bus bar would simply be connected to the negative battery terminal instead of the shunt. The shunt allows the battery monitor to record all current flows to & from the battery for purposes of more accurately determining the battery's state of charge than by using just a voltage measurement.
Before installing the bus bars, I had to connect the negative leads to the shunt, which was difficult, due to the large size of the shunt terminals & space limitations.
I wanted to illustrate this simple testing procedure which allows quick & easy checking of all three fuses without opening the box..
By using a multimeter to test for continuity between any two different pairs of the 3 positive pigtails, I can quickly tell if all three fuses are good. If one or both tests fail, then testing a third pair will confirm which single fuse is bad, as shown in the chart.
It is easy to stick one probe inside the top left power contact of the trailer 7-way plug, then touch the the other probe to the + contact of a charger and/or solar pigtail plug. That's it! - If both tests show continuity, all fuses are good. Of course, the battery switch must be on for a valid test of the trailer fuse using the 7-way pigtail.
So, if you have a multimeter, you don't need to open a junction box (or battery box) to check these fuses, if you have a charger or solar pigtail installed.
Some meters don't have a dedicated continuity test mode that beeps, but you can also use the lowest range of the resistance mode to test for continuity.
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
I had to readjust a couple of wires to fit the tight space, something I ran out of time for & had to postpone after initial installation.
The covers help prevent accidental shorting of positive & negative contacts, especially needed here where they are in such close proximity. If you're not sure what the danger is with shorts, please read @MuttonChops interesting write up about his wiring mishap & excellent recovery:
https://tab-rv.vanillacommunity.com/discussion/7467/bad-day-mod-update-broke-dc-system
I'm not sure I could think fast enough in that kind of situation, so "an ounce of prevention.." as they say.
2018 Toyota Highlander, XLE
Wisconsin
● Blue Sea Systems 2315 MiniBus 100... https://www.amazon.com/dp/B000OTJ8A0
● ONLINE LED STORE 7-Port Trailer... https://www.amazon.com/dp/B07G8S9ZCB
● 6 AWG 6 Gauge Single Black 2 feet... https://www.amazon.com/dp/B0721GBGGL
● 6 AWG 6 Gauge Single Red 2 feet... https://www.amazon.com/dp/B072MWHC1T”
Looking at “Online LED Store…” I see that the junction box contains a 7 port bus bar for the trailer wiring. Did you remove the 7 port bus or did you actually order something else? Please advise. Again, thanks in advance.
Wisconsin
As far as the wire gauge, it may depend on what all you plan to connect. I probably erred on the side of safety by using 6G cable, since I had solar, charger port, etc, but the distance was short, so I could have used smaller gauge. Since you're going a longer distance, I'd suggest being conservative too, but 6G may be ok. Perhaps we'll get a second opinion here.
My junction box got very crowded, so if you have more space in the tub without the battery, where you have more room, you may want to consider a larger junction box. It gets crowded fast when you start adding more fuses.
