I just discovered yesterday that my 2022 400 has an AC powered tv. This is problematic for watching tv when not on shore power (boondocking). The AC powered tv requires the inverter to be powered on and that thing seems to draw a lot of amps of power. In addition, an AC "appliance" isn't as efficient as a DC powered appliance when trying to conserve battery power.
I've sent an email to NuCamp to ask why they made this change. Its likely a supply chain issue, but if it isn't, I would really like to know why. Perhaps there is a good reason that I would agree with. Otherwise, I'm about to spend another $300 to buy the Jensen 12 volt model and switch it out. Not a happy camper at the moment, but open to hear their explanation before I buy the 12 volt tv.
2 ·
2019 Ford F-150 3.5L Ecoboost with Long Bed
Here are the specs for the tv we have in our 2022 400. Model JE2417 ELED TV (Note the "E" in front of the LED. Never seen that before. I see this is the most recent model release from Jensen)
The Jensen 12 volt 24" tv draws 2.307amps. If my calculations are right, the 110V AC tv draws .27 amps? Can someone check my math on this. I based it on 30W divided by 110 Volts equals .27 amps. Is my decimal in the right place!?!
If my math is correct then this seems to explain the switch to the AC vs DC tv.
Kind of hard to compare exactly, you need to compare power. The DC is 12V @ 2.307Amp = 27.7watts but the AC version is 30watts max. In addition you need to factor the inverter efficient so this max will be a bit higher.
So which one is lower, you can't tell from the numbers. The AC version says max, it is most likely on average less. The DC rated current, is that average or max?
South Jersey
To answer question from above, I'm not sure if that was the max or not. It was actually an answer to a customer question on eTrailer. I was never able to find the actual manual/specs for the 12 volt.
Brad
Concord, NC
South Jersey
Thank you for catching this. Yes, I am wrong because I moved the decimal place 2 places instead of 1. It would draw 2.5 to 3.0 Amps. I guess the caffeine wasn't working yet...I corrected the verbiage in my original post to reflect this.
Brad
Concord, NC
@subfreq111 One reason a regular tv isn't a good idea for an RV is the Jensen's are "supposedly" built for the specific conditions of an RV which would be ALOT of jostling around in transit, changing temps and humidity levels etc. Good to know that inverter likely won't use much power too. I was thinking the fan always was running, etc.
Thanks to the forum (again) for saving me $300 and a bit of labor! I will contribute that money toward the $2400 (one time personal property tax) Maryland registration fee I just paid this morning to title the T@B! Ugh. You gotta pay to play!
2019 320 Boondock Edge - Sold Jan 2022
It is disappointing that nüCamp was not pro-activate in notifing buyers, specifically 'build order' customers that a major (IMHO) trailer component change has occurred.
A notification that might have included an option to cancel or request the 12V-tv be delivered at a later date.
nüCamp of today is not the nüCamp of only a few years ago.
Their large production expansion capital requirements must have required venture capitalist [VC] investment and now nüCamp is being being forced to meet VC growth & revenue demands which always result in justifying a change in pre-VC-investment management choices - - - - i.e. Keep the Investors not the customers first.
I experienced the VC effect many times during my professional career, seen first hand how the VC effect poisons first marketing and then engineering management . . . always at the cost of the end customer
Ok so with TV on, inverter on, and a small Sony DVD player playing a DVD, I was using 3.71 amps. This would also include any phantom draws. No lights or anything else on.
Good point on the capital investment with NuCamp. I wonder if that is the case and has had an additional impact on things as well?? Shipping out trailers with changed components or without components at all, ie screen doors and widow shades.
