What is the distance of the waste tank outlet to ground, 2021/22 T@B 400 BD?
subkronsubkron Member Posts: 177
I'm looking for a portable holding tank and I want to make sure it will drain from the T@B correctly (the RV is not close to me to measure). The Rhino 15gallon tank needs 13" minimum.
2022 T@B 400 Boondock
South Jersey
  • AnOldURAnOldUR Member Posts: 1,525
    edited March 2022
    Can't give you a number for the 400, but it's about 10" on our 320. We use a Rhino tank, but have to be on a slope so that the tank is downhill from the outlet. Not perfect, but it might work that way for you also.
  • subkronsubkron Member Posts: 177
    I was hoping it work make it without finagling - maybe a 400 owner can take a quick measurement?
    South Jersey
    edited March 2022
    My guess is that your trailer being a 400 and a Boondock on top of that, it will work on level ground. The reason I brought it up the finagling is that depending on how out of level and in what direction your campsite is, there's a chance that the drain may end up lower than 13"
    The TaB400 BD black/gray tank drain is 13” from ground to bottom of the drain pipe connector on a level pitch.  On a sloped site, this could be less or more depending on the slope direction.  Mine is on a slight slope (higher on the driver’s side) so the connector is 12” from the ground.
    @Denny16 Thanks, just what I needed to know!
    South Jersey
  • TABNewbiesTABNewbies Member Posts: 93
    Yes, 13" on our 2021 T@B400 BD to the bottom of the drain pipe outlet.
    2021 T@B 400 BD T@bitha with 2016 Highlander
    Juliet and Andy in Massachusetts
