The Norcold 3104 fridge in my 2021 Tab 400 runs fine on LP and 12 volt. When placed on 120 volt AC, it trips the GFCI. Here is what I have noted:
-The fridge will run on 120v for 20 minutes before tripping the GFCI. Same 20 minutes regardless of the coldness setting.
-I have only had access to 15 amp to try the fridge. I have not plugged it into 30 amp.
-I have tried bypassing the trailer by plugging the fridge directly into an extension cord with the same result.
-I have tried it on a number of different GFCI outlets.
I suspect a faulty element as it takes 20 minutes (heating up?) for the GFCI to trip.
Any thoughts on this? Or should I just look for a Norcold Servicing Dealer?
It does not appear that one can access much through the sidewall vents and most work would require removal of the fridge.
2021 T@b 400 Boondock
Oneonta, NY
0 ·
On the 320 models the 3-way Fridge has a dedicated 120V Circuit Breaker.
That is, on 320's there is no Fridge GFCI protection.
Does your Fridge have a standard power code plugged into a 120VAC outlet [like the Alde does] ?
If so unplug Fridge, reset everything and figure out which outlets share the circuit with the Fridge.
A helpful item would be Pictures of your 400 model WFCO Power Center:
-+- How many circuit breakers
-+- How did nüCamp label them (label may not be near breakers)
Also, on 120AC the N41nn 3-way series Fridge draws <= 2.5 Amps.
The maximum draw would be on start-up and when the heaters restart based on Fridge temperature. So your GFCI tripping at 20-minutes is weird . . .
The 400 Model Users Manual [version TAB400-MAN-002] only shows how the 2-way Fridge is always on 12VDC via the convertor or battery. The manual does not include any reference to the 3-way Fridge on 120VAC power in the 120v Panel (circuit breaker) section.
Oneonta, NY
This seems to be a somewhat common issue when plugging (newer) RVs into a GFCI protected outlet. It is caused by the GFCI present in the RV that causes a slight current imbalance which makes the house GFCI even more touchy (we're talking single digit mA).
As an experiment turn off all breakers inside the T@b except for the converter and the fridge. If it works fine then, that confirms it.
See: https://tab-rv.vanillacommunity.com/discussion/15050/power-to-norcold-3-way-only-from-tv#latest
This could be a similar issues with a loose ground on @Gherzig fridge, ground coming off after 20 min. Seems the Norcold 3-way fridge needs a good ground connection to work properly on shore power.
Oneonta, NY
