While researching which lithium battery to purchase for our 2022 320 CS-S, I've noticed that many people indicate that after purchasing a battery online, the first thing they need to do is charge them. I was under the impression that (once installed on the TAB) the battery would charge when connected to shore power. Is that true for LiFePO4 batteries? Is a portable charger needed as well?
2022 T@B 320 CS-S Boondock
2018 Nissan Frontier 4x4
SW Ohio
0 ·
Brad
Concord, NC
SW Ohio
Real life update using WFCO-8725 converter charging Renogy 100Ah smart lithium battery.
My initial tests indicated I could reach a 84.1% State of Charge (SoC) just using my stock WFCO converter.
In real life use I have found that I can reach a 94% SoC just using the converter alone. I am pleased with those numbers. The difference came by having the T@G battery switch ON and under a small load (Norcold NRF-30 refrigerator). I assume this made the converter run more in the "Absorption Mode" (13.6 Vdc) or the "Bulk Mode" (14.6 Vdc) as opposed to the "Float Mode" (13.2 Vdc). 94% is good with a 100 Ah lithium battery.
I will be curious how much of an increase of SoC I will get using my solar suitcase. I should be able to get up to 100%.
Since my shore power camping is limited (less than 3-5 trips a year), I wonder if changing to the new WFCO-8725Lis will be worth the effort.
Time will tell.
A basic question I have is without a lithium charger how do you know when you're at 80% or 90% or 100%? In the initial setup my battery monitor requires me to tell it where the battery is in its charge cycle. The only known points are either no charge (0%) or full charge (100%). I charged the battery as best I could with the controller and told the monitor it was 100% - but I don't know where it truly is.
We went boondocking for 3 days last week. I have the stock rooftop solar and a Renogy 100a solar suitcase. I was hoping to get a full charge from those because both have lithium settings and I would then be able to define 100%. But alas, it was cloudy and rained.
Regardless, I did notice that the converter would charge to about 85% and then reduce charging to a float mode. It I disconnected the battery with the battery switch in the tub and then re-connected it again, the converter continued to put a charge in the battery and it reached close to 100%. Or at least what I defined as 100%.
I ordered a lithium capable battery charger yesterday. I have other batteries to charge as well so it's not just for the trailer. When I get that I'll be able to get the battery to 100%, reset the battery monitor, and be better able to tell what the on-board charger is doing.
2017 F-150
Coeur d'Alene, Idaho
13.6V = 100%
13.4V = 99%
13.3V = 90%
13.2V = 70%
13.1V = 40%
13.0V = 30%
12.9V = 20%
12.8V = 17%
12.5V = 14%
12.0V = 9%
I was reaching high 90% state of charge with the stock 8735 converter, but most of the time this was at home charging and not necessarily with any higher load than parasitic drain.
The unit will be Lithium ready. You will not need to do anything to get your unit ready for lithium. You will want to go into the Victron app and change a setting to make the solar work more efficiently with the lithium. But nothing else would need to be adjusted or changed. "
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
