Considering 2018 320 S
Wondering if there is anything good or bad we should look at if we go to look at some of these that are available?
  • Grumpy_GGrumpy_G Member Posts: 674
    Generally speaking T@bs hold up better than most of the other brands. Things to look for are cracks in the outside plastic, dents in the outside skin, signs of corrosion and/or leaks around the Alde system and the convectors. Don't remember when that was but at some point the body was put offset onto the frame. In rare cases that required a spacer on one of the wheels, you probably want to avoid these. Also check for cracks near the front of the frame.
    Otherwise the usual RV stuff, does everything work, how old is the battery, how do the tires look.
    edited April 2022
    Also, Oct-Dec 2017 and Jan 2018 build month TaBs had a floor issue, whic nüCamp had a extended warranty repair on.  Some i
    of these units had a floor buckling issue on the floor covering delaminating from its Greencore underlayment.
    edited April 2022
    Here is a list of changes specific to the 2018 model year.
    Early 2018 Models
    The 2018 T@B models were streamlined and renamed as T@B 320 S/U and T@B 320 CS/CSS. Outback model renamed “Boondock”
    Single sewer outlet
    Different upholstery
    CS models with standard front counter and cabinets
    All models with standard front window and outside shower
    Options: Solar flexible panel 190 watts, RoHS PWM bluetooth charge controller Porthole option in wetbath
    Late 2018 Models
    Alde 3020 HE with high altitude adjustment beginning with December 2017
