Adapter for King Omnigo Portable OTA Antenna to painter’s pole
For those of you who have King Omnigo Portable OTA antennas looking for easy way to put on extendable painter’s pole. This works great. Screws on end of painters pole and won’t  come loose. Magnetic Pick-Up Tool Attachment, 3.20" Diameter, 0.440" Thick Magnet Assembly with Acme-Threaded Attachment for Standard Broom Handle, 65 Pounds Pull, 1 Each https://www.amazon.com/dp/B000N8NI7G/ref=cm_sw_r_cp_api_i_CD77CBB6D9GFDQFYXR75?_encoding=UTF8&psc=1
Trips - 48  Mileage - 63,452
  • BaylissBayliss Member Posts: 1,492
    Thanks for the tip and link, @rcarlson1957.  I've been contemplating going the painter's pole role route for my OmniGo antenna, so the information is very helpful.
  • ColoradoDJColoradoDJ Member Posts: 8
    I’m glad you found something, Rick. That looks better then what I put together.
    2017 T@B 320S Max silver on silver “Tabin”. 2009 Toyota FWD White Tacoma Double Cab.
    Leonard & Ronna, (Fort Collins, CO)
    ”Need More Cowbell”
  • MarcelineMarceline Member Posts: 1,745
    The magnet doesn’t cause interference with the antenna?
    edited April 2022
    Apparently not Marceline, my cell booster antenna has a magnetic base also.  Works just fine on top the TaB.  That said, you need to fix a painted steel washer to the TaB’s aluminum roof for the antenna’s magnetic to attach to.
