Does anyone know where to buy this Alde Antifreeze in the U.S.? I checked the Alde U.S. based branch and I don't see it on their website. I'm due to replace the glycol this year and I wanted to replace with this 5 year type. I tried calling Alde, but I bet they are shut down for Christmas.
Also, how much glycol do you need for a T@B 400? I see the ratio of antifreeze to water is 60% distilled water and 40% glycol so trying to figure out how much to order if I find it.
Thanks!
{Added disclaimer to title to alleviate confusion—Verna, T@B Forum Admin)
This is what a number of folks on the forum are using, but not labeled as 5 year fluid:
https://www.amazon.com/Century-Chemical-TF-1-Transfer-Fluid/dp/B01BDWQXM2/ref=pd_bxgy_2/146-3680374-3284725?_encoding=UTF8&pd_rd_i=B01BDWQXM2&pd_rd_r=9bb93260-c440-4896-8435-ce5daf46037a&pd_rd_w=rQk8W&pd_rd_wg=91I5h&pf_rd_p=f325d01c-4658-4593-be83-3e12ca663f0e&pf_rd_r=Y9ZK9MVX2VFACWD35PFG&psc=1&refRID=Y9ZK9MVX2VFACWD35PFG
Amazon.com: Century Chemical TF-1 Heat Transfer Fluid: Automotive
This product is used full strength. Not sure of a quantity for the 400.
Edit: Looks like others (above) read the same posts as me...
2019 320 Boondock Edge - Sold Jan 2022
I emailed Truma (Alde), their recommendation is to use the new Alde branded fluid ("G13"), which is what NuCamp also seems to recommend, but also still on a 2 year replacement?
What's not clear to me is if the new Alde G13 spec fluid is "GRAS" (Generally Regarded as Safe).--Is US Alde G13 different than European G13?
Truma quoted $55 per gallon, a call to my local dealer quoted $70 a gallon (or $680 for the fluid exchange if they do it).
I'm looking at the DIY pump options, and if G13 is the same (toxic) in the US or Europe, any reason not use $20/ gallon US brands like (Prestone, PEAK, Zerex)? Even that has some grey area, G12++ is pink, or blue (compatible with G13), and the G13 is purple/violet (or also blue?)
Clear as mud.
Since mine is not under warranty, I think I'll use the previous recommended Century TF-1 (Yellow) for now, and see what "evolves" as far as recommendations two years from now...
"Bafflegab" is a good word. I have no idea why this relatively simple topic should be subject to so much confusion and secrecy.
I get the impression that Alde branded fluid in USA is not same as Alde branded fluid in Europe.
There are other brands besides Rhomar in USA available at HVAC supply houses, some of which are designed specifically to protect aluminum.
The problem is if you do something off book, you may be on hook for big repairs if it turns out to be a bad experiment.
So I ended up sticking with the then Alde USA recommended Century TF-1. Shortly afterwards, Alde/Truma US changed their recommended fluid to the Rhomar fluid, which was being used on new production TaB in 2021.
Older units built before Jan 2021, can still use the Century fluid, but can also have their system flushed and replaced with the new (improved?) Rhomar fluid.
Personally, I would stay with the Alde recommendations for North America units. Why take unnecessary risks with an expensive bit of kit, just to save a few $.
Brad
Concord, NC
https://tab-rv.vanillacommunity.com/discussion/14169/experience-2014-alde-flushed-refilled-with-rhogard-concentrate#latest
St Catharines, ON
TV 2025 Telluride X Type
