My 2022 320 CS S boondock is equipped with a 12 V flooded lead acid battery rated at 81 amp hours. It has the factory equipped 100w solar panel. I’ve discovered that camping off grid, this is just enough to run the Alde for 3 days for 5 or 6 hours at night to keep the battery above 50%. Other than phantom power, nothing else is drawing current.
I’d like to improve this setup so I could do 5 or 6 days of de-winterised summer boondocking using the pump, fan and 2 way fridge. I’ve read what I can here and elsewhere and I guesstimate this might use about 40 amps of power daily (which is pretty much the limit of my battery’s capacity, if I understand correctly).
My questions are:
I’m at the point where I’ve gathered just enough info to completely confuse myself, so if I’m speaking ishkabibble or if you have other suggestions, please let me know. Thanks!
managed by VE Smart Network
I think getting a battery shunt of some kind is important. The Victron SmartShunt is very nice but spendy. I went with a hardwired Qwork shunt for $40. Regardless, a shunt allows you to really see what's going on. The Victron app for the stock MPPT solar controller also provides a lot of useful information.
Look for and eliminate as much parasitic draw as you can. I removed the television since we never use it and installed a cutoff switch on the Jensen radio. Parasitic draw is now in the range of 0.155 amps.
The Fantastic Fan in stock mode draws quite a bit of power. I did the $10 PWM mod that results in variable speeds. Draw now in low speed is around 0.14 amps, 0.34 in medium and 0.9 on high. I think the clamshell has a propane cutoff switch that draws a bit. You can modify that to reduce power consumption.
With our current setup of a 100ah lithium battery, rooftop 105w solar, 100w portable solar, and our frugal electrical lifestyle, I'm pretty confident we can get through long boondock trips even with suboptimal sunshine. Time will tell. We're soon heading out for 20 days with only a few stops that have electricity.
To answer your questions, I think a 200w panel would more than suffice. There shouldn't be any issues with hooking up the panel. And I think you might be fighting a losing battle with the stock battery and your desire to boondock for 5-6 days (or at best living on the edge). That being said, there are people who have been happy with the stock battery setup and do just fine.
2017 F-150
Coeur d'Alene, Idaho
2022 F-150
Gratitude
The PWM (pulse width modulation) does something fancy inside that reduces voltage by varying the width of the on/off time the motor receives power. For the mod, you bypass the rheostat and wire in the PWM to control fan speed.
The best explanation that I found of the mod is here:
http://ourelkhorn.itgo.com/camperII/fansw.htm
It has schematics and pictures that you can follow. The mod results in a continuously variable speed fan. It also retains the ability to reverse the fan. It is much quieter, you can set it at any speed, and it's energy efficient. You can do the mod from inside the trailer and there is no need to break any seals or caulking on the outside. I hope this helps. Good luck if you pursue this!
2017 F-150
2017 F-150
2022 T@b 320 S / 2021 Subaru Outback
We use the Ecoflow to charge batteries (camera, etc.) and also run a heavy gauge AC line cord connected to the "shore power" input plug to the trailer when extra power is needed off grid. This works well for us since we tend to leave the trailer as we drive to nearby scenic areas to hike. As we drive, we top off the Ecoflow. Of course, this is not perfect but it does give us additional power for those overcast/rainy days. a generator would be another option but I really don't want to lug one of those around...noise, gas and etc.
2021 T@B 320s Boondock "Pull-T@B"
2024 Nissan frontier Pro-4X
South-Central Indiana
