On our yearly shakedown trip we discovered that our outdoor shower head must have had water in it over the winter and froze/cracked. I need to replace the shower head, but I'd like something both with a longer hose and much better flow. Anybody have suggestions that will still fit in the existing box? Looks like replacing the whole box isn't an easy job.
2020 T@B 400
2019 Toyota Tacoma TRD Off-Road
Seattle, WA
0 ·
https://www.amazon.com/gp/product/B07Y1WB59Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B087M8DNZ2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B003LY7GWC/ref=ox_sc_saved_title_10?smid=&psc=1
Not only have I sprayed my self by not turning the valve off, but also discovered that if you don't release the pressure in the hose after shutting off the valve you'll get almost as wet.
"Just Enough"
"Just Enough"
Also have to apologize for the bad link. The first three items are what I purchased, but the last CPC discount link was not. I had a lot of CPC fitting from my homebrew days and used what’s shown in the pictures. The Amazon CPC link was only to show the brand and did not include both the male and female connectors or the exact versions needed. I should have been more specific. I’m glad you were able to work it out to your satisfaction, but if you’re still interested I’ll look for links to the CPC fittings that will work.
https://www.zoro.com/colder-12-mnpt-coupling-insert-hfcd24812/i/G2953021/
2022 T@b 320 S / 2021 Subaru Outback
