Electric tongue jack a hair to big?
jkjenn
Member Posts: 6,421
I am in the middle of replacing my to gue jack with Northern Tools Ultra Tow 3500 lb jack. All is going swimmingly, but I might have reached the point where the jack gets returned. The new jack fits through the top hole, but not the second hole.
Am I missing something obvious, or should I go ahead and return it? I have no desire to grind the hole to expand it.
Without taking a bit off the lower hole, I wouldn’t have been able to install an ultimate jack. It didn’t take much for it to fit.2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts2 -
Thanks, I am getting similar feedback on FB.DenisP said:Without taking a bit off the lower hole, I wouldn’t have been able to install an ultimate jack. It didn’t take much for it to fit.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
@jkjenn - https://tab-rv.vanillacommunity.com/discussion/7149/ucamp-18-power-tongue-jack-conversion-modSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Jkjenn..... very easy to grind that second hole enough for it to fit. I bought the manual ultimate jack and same thing happened. It's just a hair to large for second hole. I used a drill with a grinding type bit and it was very easy to make the hole little bit bigger. I marked around the bottom of the jack post with a white china marker so I could see what needed to come off.
This is the bit
SB-3 Tungsten Carbide Burr Rotary File Cylinder Shape Double Cut with 1/4''Shank for Die Grinder Drill Bit https://www.amazon.com/dp/B086S2FLR7/ref=cm_sw_r_apan_i_3E2XE6CB8BFM1XBADWJG?_encoding=UTF8&psc=1
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
