I recently purchased a Renogy 12V AGM battery.
I measured the voltage out of the box to 13.00V
During our first trip we went as low as 12.58V
After recharging (and allowing overnight settling without charging) it is back to 13.00V
Now, I have found lists like these to interpret the voltage in terms of % remaining charge:
I have seen similar lists posted on this forum.
According to the list, I would be at 90% when seeing 12.62 on the meter. But that seems inaccurate, considering my 100% is 13.00.
Some adjustments should be made. I'm just speculating, but how about something like this:
100% - 13.00
90% - 12.88
80% - 12.76
70% - 12.63
60% - 12.50
50% - 12.38
Adjustments??? Thoughts???
Did anyone else run in to this "issue"? Is Renogy at fault for increasing their voltage (to make it seem like it has more charge than it does)?
Basically, I am trying to get a better idea, so that I don't assume I have more charge than I really do and drain my battery and run it down prematurely. I would at least like to know what my "bottom" is. I guess if I stay above 12.38 I'll be ok, but maybe that is overly cautious?
Thanks,
2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD
https://renogy.com/blog/expectations-vs-reality-making-sense-of-battery-voltage-percentages/
AGMs are more resilient to deep discharges than traditional lead acid. Many folks run them down to 20% or 30% remaining rather than stopping at 50%. One member here did the calculations and determined the overall lifespan of the battery was shortened by very little doing that.
If you’re using a Victron shunt to track your usage, you can set the 100% voltage to match that of the battery so your readings are more accurate. If you’re not using a shunt, it’s one of those things I’m still kicking myself over for waiting so long to buy one…one of the best upgrades you can make for boondocking.
Basically voltage is not a good indicator of SOC because it depends on the load on the battery. I have seen "shot" batteries that had over 12V open circuit voltage but drop below 11V with any useful load.
I took a screenshot of the chart, to keep it for myself:
So it, seems like the spread of the chart is greater for the AGM. Dropping around 0.25 initially per 10% drop, as opposed to 0.12 in my guesswork.
That's great to know that I was being overly cautious and it seems I can go down to 12.05 with less worry!
Grumpy, yes, I have noticed that the voltage reading drops, when connected to stuff that is pulling from the battery. I guess the best way to get a good read is to shut of the battery switch and then read it.
My 12.58 on the trip was taken when connected, so switched off it may have been 12.68 or something, so about 85%.
pthomas, yes a grain of salt is probably good to use here!
My 2018 320S has an Interstate Batteries Marine/RV lead acid battery (model HD24-DP). According to the manufacturer's website, it is rated at 64 Amp Hours. It also says the battery has a "reserve capacity" of 100 minutes (???).
I am trying to figure out what the 50% state of charge level is, both for my own information and because my son is going to borrow the trailer so I want to make sure he keeps an eye on it while boondocking.
After reading this thread, and the related "Battery SOC vs Internet myth" thread, linked above by @Grumpy_G, I am very confused.
Personally I use the reserve capacity and calculate Wh from it which is a pretty decent approximation of how much energy can be drawn from the battery before the SOC gets dangerously low.
Where is it located?
Thanks
Controllers were only installed if you had onboard solar, which was an option by 2018 if I recall, but didn’t come standard on any trim level of the 320 until the refresh in 2021. Zamp panels come with their own (as do most suitcases), so the Zamp port wouldn’t have one connected.
The case says Zamp Solar on it. There is a connection in the propane/battery box on the front of the trailer for hooking up the solar panels to the battery. If it was all optional, I am guessing the previous owners added it when they bought the trailer. Maybe that's why I have a Victron monitor???
