2008 T@B trim seal replacement
 I just bought a 2008 T@B and want to replace the trim seals, they are missing. I don't have a dealer near my home and wondering if someone knows the part number or equivalent replacement I can purchase elsewhere.
  • gtstoysgtstoys Member Posts: 8
    @Carnet1098 You have to call Elsie at NuCamp to find the part number and availability of the replacement seal. Then call the nearest dealer or out of state dealer from you to order the part to be shipped to you.  Unfortunately, I do not have the part number any more because I replaced the black rubber trim seal on my 2008 T@B over a year ago and threw away the box.  Another thing that you have to do is to measure the length of the trim seal that you need (both sides) and add a foot or so extra on the measurement.  Good luck!
     B)  TV - 2004 Toyota 4Runner V6 Sport Edition
    edited September 2021
    @Carnet1098 - email Help@nucamprv.com and request the part number.  A photo may help.
  • BillKBillK Member Posts: 1
    Using information from previous threads and measuring the existing trim on my 2006 t@b I replaced my trim with a third-party product. Being in Canada my nearest dealer is 500Km away! The plastic trim is .08 inches thick, so I found some automotive trim from Trim Loc. It is available in 25-foot rolls from amazon, which is perfect for each side, The product is Trim Lok T4L-DD120125 25 ft. Co-Extr EPDM Trim-Flap Seal. It is available with either a .5-inch or 1-inch flap. The existing flap is .5 and I went up to 1 inch to improve the seal. It was excellent!
  • GeoGeo Member Posts: 160
    @BillK,  I did a similar fix with an auto replacement trim from an on line parts supplier in '07. Very secure fit and has not come loose yet.
    Geo & Liz
    T@BMahal
    '04  #100
  • CnAFergsonCnAFergson Member Posts: 5
    I tried to search Amazon and nothing came up. Probably user error but would you have a link to the product by chance?
  • rfuss928rfuss928 Member Posts: 1,159
    edited June 2025
    Try searching:
    rv trim molding insert
    Check the width of the gap in your trim to narrow the search.  Lots of choices...
    Fold about one inch of the material under each end to double the thickness and tighten the grip of the seal in the grove.  A screw through this doubled end will assure it doesn't come loose and end up on the side of the highway.
