The front panel already has insulation in the roof panels but if you want you could add more, I’m not aware that we install any insulation on the cabinet divider panels at all.
I believe it could be done if you wish it would help cut back on heat transferring the rest of the cabinet. (you would need to pull the fridge to do it and that isn’t an easy tasks with the vent pipes going out the front of trailer)
It shouldn’t be a problem with air flow.
There is a hole coming up from the bottom of the cabinet that provides fresh air intake for the fridge cabinet be careful that doesn’t get covered up in any way.
****end****
I was thinking about cutting insulation in pieces and just drop them in between the front panel and fridge when I removed the vent. You might want to bring some insulation and ask the dealer to stick it in there when they replace the vent. It is easily reachable.
But remember, installing the fan itself make a huge difference. Adding some more insulation is just an option you might want to consider if you camp under direct sunlight often.
Jiro
That sounds like a great idea. I know that my husband does this for his computers and it works quite well moving the hot air out. Would probably work just as good with the T@B.source3 said:Just installed the fan upgrade today. What a pain, I had to trim both the fan housing and the hole in the T@B. Hey FACTORY, use two smaller fans! The pdf was helpful for wiring. However, illuminated rocker switches commonly use the middle terminal for 12v+ coming from the battery. I switch the red and yellow wires on the switch. I confirmed that the yellow wire was from the 12v+ battery looking at the Norcold wiring diagram.
So the new 2016's will have the smaller fans once they get them or since the fans are being installed when they are made, it's not an issue? Just the kits will be made with smaller fans, anyone know? Since we are special ordering, just wanted to know.PXLated said:Source3 - I think the factory guys said they are sourcing smaller fans - this version of the kit was put out fast with what they had - kudos for a quick response - I guess we should treat this as a beta :-)
I had the new fan/vent installed last week. The A/C was even cooler at night, and the counter was very much cooler. There is the on/off switch that is installed above the fridge, so you don't have to use the fan in the winter when the heat can be put to good use.
Yes, Marvin told me they are making the fan/vent fixtures in-house, and even he and Austin had to trim the walls and still pound the vent into place. As PXLated said, we're fortunate that we're working with a small company who can make quick changes within a week or so and come up with a solution. Many larger companies would still be trying to come up with a solution.
And, I did discover that due to the cooler temps last summer, the hot counter was not discovered in the 2014 models until this year with the warmer temps. Therefore, the problem has surfaced only this year and once again Pleasant Valley listened to what we say on the forum. I only have praise for their quick response.
