Hi savvy RVers,
The dealer installed a solar sidewall port and I'm thinking of finally getting a panel.
I camp for maybe 3-5 days, twice a year HOWEVER... I'm thinking it may be useful when the grid goes down for two weeks, etc...
Is the panel below overkill??
Thanks for your opinions!
And lastly, you’re not limited to Zamp panels. Other brands will work if you want to either save money or get more panels for the same amount. You need to know whether your port is connected to a controller already (probably isn’t) so you can pick a suitcase with or without a controller as needed. You may also need reverse polarity adapter, but that’s cheap and easy to get/use.
"Power consumption (W/24h) = 360 W, 30WPH. Not sure if they used this on the 320s in 2018, but it was part of the original 2018 TaB400 builds
I would consider switching the battery to a 100amp lithium, and get a Renogy TypeError flexible solar panel suitcase setup, 100-150 watts should work fine.
it’s a 3-way fridge.
Denny:
That’s not the model # of the fridge on my Tab…
Thanks for the suggestion.
I’ll add it to the research!
Much appreciated!
1) What 100 amp lithium battery would you recommend?
2) What does the 100 amp lithium buy us over our standard 80 amp wet cell battery in terms of capacity?
4) Without the sae port how would the Renogy connect to the battery?
5) Living in NW Ohio, winter can be a challenge, with temps sometimes below freezing for weeks. We've even had weeks of below zero temps in the not too distant past. How should the battery be managed under such conditions?
Thanks, Jerry
goid to know!
1. I looked at Renogy and Battleborn, best warranty and reliable.
3. The lead acid, followed by the AGM. A lithium is about half that weight.
5. Good lite batteries have an option for battery heater built in. Also since the battery is in the Tub, two bolts and remove the battery and take it inside for the winter where it can be kept aboveb 0F
6. Not that I can think of.
Thanks, Jerry
Trips - 48 Mileage - 63,452
