This is on the FB page this morning. Still sorting out the details, as in was the battery seriously discharged and this happened when it was plugged in, what is the status of the Gloso breaker, etc. Many guesses in the comments: would a converter set to Lithium do this to the AGMs? Can the Gloso breaker fail?
Any ideas? Sure is a dramatic photo, though.
Fuses and breakers are fine though, so maybe not.
2b
Anyway, the converter seems the likely culprit, hopefully still under warranty.
1) Internal short or Negative-Positive terminal direct short.
2) Over-Charging . . . too much current into battery.
In both cases the battery acid begins to boil off and since the battery is sealed the case must expand. This process also creates a sulfur 'rotting eggs' odor.
The greatest danger is the case failing allowing battery acid to leak/explode all over the battery compartment. In general this type of battery failure is not a fire hazard.
For the batteries shown/discussed in the Facebook post - - -
My vote is with the Power Center having failed in some type of higher than standard output current mode.
https://dragonflyenergy.com/thermal-runaway/#:~:text=Thermal runaway is a chain,to occur inside the battery.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
