Background:
    Every few months someone asks for a 400 Wiring Diagram to help troubleshoot an electrical issue.  Yet, while the Model 400 has been available since 2018 no single owner/forum member has created a useful Wiring Diagram.   Of course the 400 is very similar to the 320S which has excellent owner created documents for the 2016'ish model-years.  Those diagrams are indeed helpful for troubleshooting newer 320's and model 400 issues . . . a TaB is a TaB  after-all . . .
Task:
   Since no 400 owner has had the time/skills/tools to create a full Wiring Diagram
 - - - is it time for a Forum Group Effort to create a Wiring Diagram ? ? ? - - -
I've started a basic Wiring Diagram.
Input from 400 owners on whats what electrical circuit wise would be helpful to complete a usable Wiring Diagram for everyone.
Your Inputs Are Needed.
Pictures of the circuit labels nüCamp installed on the Power Center Door.
Your own data from tracing out which outlets/etc are connected to which circuit breaker or fuse.
{{ edit 060522 removed ver00 diagram, see next post 06-05-22 for ver 0.1 }}
As a 320S owner why do I care?
  1st  I like helping folks isolate/troubleshoot electrical problems and a more complete Wiring
      Diagram would be helpful in both finding & communicating the problem source.
  2nd  While I'm super happy with my 320S, I keep daydreaming of something different/newer
      and a model 400 is on the possible list . . .
The 320S Wiring Diagram created by Rick Parco is excellent and the milestone to match for any other TaB model documentation.  That said, I do not have access to an as powerful Electrical Wiring Harness CAD program as he used.
So the attached file is a bit basic/crude . . . .
based on Forum issue information and review of a detailed 2022 model 400 walk-through.
It would be very helpful to have model 400 owners;
photograph the nüCamp labels on the Power Center regarding AC Circuit Breaker and DC Fuse assignments.
Please include your model year, info on Fridge type, solar panels installed or not.
Updated ver01 diagram attached (picture file).
By searching forum posts, watching different youtube reviews/mods, and with three helpful folks getting me Power Center pictures the Diagram Content has really improved. ( will work on style later )
More 400 Owner information is needed:
- As there are some points that are not clear.
The diagram focus is "typical" wiring diagram based on the 2020-2022 years.
For any owners in that year range that have Traced Out / Confirmed the nüCamp 120VAC and 12VDC
Power Center labels vs. actually what is powered and are open to sharing please do . . .
{{ that does not change my disappointment in many of the recent model-year
'enhancements' made to the 320 - - - I would not buy a 2022 320 . . . the 2018 I have is near
perfect and the recent 'enhancements' have made the 320 less perfect (imho).
But that's way off topic
The Inverter on the 2018/2019 is on,y wired to a single outlet under the TV bunk end panel.
If/when any 2022 400 owners share their Circuit Tracing experience/knowledge a future update could be possible.
Hopefully the ver 0.3 Draft document attached will help someone during their troubleshooting of an issue or project planning - - - not as an official Your Trailer is Like This - - - but more as an educational aid providing things to consider while working on your specific trailer.
Time for a new rainy week project.
On page 2 you have the extra solar port going to the controller, in actuality it goes to the distribution block. The integrated solar panel goes to the (single channel) solar controller.
South Jersey
Thanks for the input.
Attached PDF file has the Solar Wiring changes.
Note the updated sheet also moved the Current Shunt position,
- - - do things look correct now?
I've included a new 4th sheet with a Ground System Overview.
P.S. I'll wait for more comments before issuing an all-pages-update.
1. The Inverter is wired directly to the battery terminals, not the junction box, and has its own large cartridge fuse in line between inverter and battery.
The 2019 & 2020 builds seem to be as shown on the Draft Wiring Diagram.
Here are the 'source pictures' I used to make the diagram:
2019 Tab 400
- one to the junction box
- one to the Power Center (convertor)
That would be a different wiring approach than used on the 320 models
Do you have a picture
South Jersey
The inverter wires are going through the plywood divider to the black battery distribution/junction Box, which is mounted on the other side where the battery cables go through wire glands to make the battery box sealed. This one was modified by the owner to install the Victron Shunt, adding the black negative cable to the shunt behind the inverter, instead of to the junction box. Battery box is vented with the large hole next to the battery cable penetration point, and is sealed from rest of the TaB interior as required by RIVA.
