Refrigerator Knob cant be turned off!
Falcon_teardrop
Member Posts: 5
I was turning off the fridge and maybe have twisted a little to hard, felt a sorta "double click" and now i cant get the fridge to turn off at all. I pulled the plastic knob off too try and turn/click it off with pliers but cant get it to turn and don't want to damage it further. Obviously we cant keep it on. We actually rarely use it. Has this happened to any one else??
2021 T@b 320 CS-S
So California
So California
Which fridge, model and year of TaB?cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
Sorry Should have stated. 2021 T@B 320 CS
2021 T@b 320 CS-S
So California -
Norcold NR740BB2021 T@b 320 CS-S
So California -
Are you sure that it's not turning off when the knob is all the way to the left?Falcon_teardrop said:Sorry Should have stated. 2021 T@B 320 CS
Do you hear the compressor running?San Francisco Bay Area
Yes, and the light stays on.2021 T@b 320 CS-S
So California -
Here's another thread about problems with the control knob.
Until you can figure out how to fix the knob, the suggestion to pull the fuse should work.San Francisco Bay Area
The fridge light stays on, even when the temp knob is moved to 0 (off position). The light only turns off when the fridge door is closed, or the power to the fridge is off. You can tape the door slightly open, to vent the fridge, without the light coming on. This is what I do when not using the fridge. If you tried to run the knob past 0 it might now be stuck or jammed with compressor turned on?Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
Thanks. Pulling the fuse is a great idea for a temp fix. Going to do that. Hopefully i can get the knob fixed somehow.Marceline said:Here's another thread about problems with the control knob.
Until you can figure out how to fix the knob, the suggestion to pull the fuse should work.2021 T@b 320 CS-S
So California -
We had a similar problem with the Norcold fridge in our 2019 400. However we were and are able to turn it off and on etc by removing the knob to use pliers. It had and does seem to turn the opposite direction it should.
That all being said I (husband) accept responsibility for turning the knob the wrong way and forcing it. This caused the plastic knob to stretch and no longer turn the metal stem of the thermostat. An internet search and call to Norcold to replace the knob were frustrating and left my wallet quaking.
A visit to a good hardware store with an expansive hardware selection resulted in several items intended to tighten the knob’s grip. A 3/8 C clip fit snugly on the the shaft of the knob. Knob now functions.
We are careful with it.Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
- 916 Introductions
- 72 Teardrop Groups & Links
