My 2021 Tab 320 CSS has a faulty LP Safety Shutoff Valve (the one mounted under the TaB base/floor where it connects to the clam shell stove). Did all the trouble shooting.  LP gas is working at the auxiliary port (where BBQ grill connects), battery fully charged.  The stove is not getting LP gas.  Checked the shut off valve and it was warm to the touch, possible short, so I disconnected the plug to the unit.  Spoke with a TaB technician and have ordered the replacement safety shutoff valve.
Has anyone replaced one of these?  Any advice is appreciated.
                0 ·
Your troubleshooting sounds complete so this request is for my education.
Since on (my) 320S there is the Propane Tank, a Pressure Regulator, and as far as I know no additional cut-off valves excluding the ones inside different brand name appliances.
As for replacement tricks . . . I cannot even get water connections not to leak the first
two/three/four attempts so I rarely try 'gas' lines without lots of praying & soapy water handy
